Question about Breadman TR444 Bread Maker
How do I adjust my breadmaker for high altitude baking?
    Filmmaker:
    Uploaded 5 video answers.
  • 75 Answers
Hello, you dont adjust the machine, you adjust the ingredients. what you want is that perfect ball during the mixing cycle, not too sticky but a perfect bouncing rolling ball.
Posted on Mar 18, 2015
6ya staff
SOURCE:
Are there more recipes for my Crofton bread maker. I'm afraid that I haven't had a lot of good success with it recently. I have used Wrights complete bread mixes, they always dip in the middle
Hello, Julz -
Instead of looking for more recipes for your Crofton bread maker, or any other bread maker, I looked for information as to why the bread made with a bread maker would collapse on top.
The answers I found on this online baking formum:
http://www.thefreshloaf.com/node/9725/bread-machine-loaf-collapse-when-baking-starts
may prove instructive.
To summarize, some of the causes and remedies for bread maker bread collapsing on top:
- You may reside at a high altitude and have not adjusted the recipe so that it does not over-proof [over-rise]. Cut down on the yeast, sugar, and salt.
- Even if you are not at a high altitude, try a recipe with reduced amounts of yeast, sugar, and salt (try reducing the amounts by 1/4 to 1/3)
- Use the dough mix cycle; Then turn the machine off and let the dough rise a little less than the recipe calls for; When you see the dough has risen turn the machine on to bake.
- If your bread maker allows,.reduce the amount of time between rise and bake
If you want additional bread maker recipes, you will find more here:
http://allrecipes.com/recipes/338/bread/bread-machine/
I did find a PDF document (Adobe Reader software - free) for a model of a Crofton Breadmaker, model MD 8505. In case you do not have a manual for your machine. The manual I found has information on how to make adjustments for altitude (page 22) and other adjustments to make (pages 23 - 24), including what may cause the loaf to fall while baking. This is the link to the manual:
Best wishes.
Feb 06, 2018 | The Kitchen Appliances - Others
High altitude operation of a ryi2200 generator (5000 ft)
You require a high altitude carb (or carb jet) to operate correctly at this altitude. The jets are smaller to compensate for the thin air.
You need to get in touch with Ryobi to see if they sell them.
Do not adjust anything else on the generator!!!!
Dec 22, 2016 | Electrical Supplies
We want to just make dough
According to the manual, page 23, "H:HH" means "Temperature in breadmaker is too high". The solution is to "Press the Stop button. Remove the baking pan, leave lid open and allow to cool. When cool, put the baking pan back in, set program and start the program again."
If you need a manual, you can download one here:
http://www.morphyrichards.co.uk/Pdf/IB48286.pdf
Apr 19, 2014 | Morphy Richards 48268 Bread Machine
What is the high altitude adjustment required by the manual?
the high speed adjustment needs to be richened up to compensate for the lean air mixture at high altitude. it can run but will run fast and may damage the unit because it is lean. the high speed adjustment is the one marked H or the screw farthest from the engine. turn it counter clockwise while running at full speed until it runs at the correct RPM. any small engine repair center should be able to do this for you and keep you from causing irreparable damage
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 27, 2013 | Toro 2-Cycle 25.4 cc Power Head 51944
Weedeater featherlite high altitude carb kit
There are not different jets for the carburetor, the only thing you can do is to adjust and run high octane fuel.
Sep 15, 2017 | Weedeater Garden
Johnson 40hp- won't idle or troll at high elevations
Depending on the year model you may be able to adjust the mixture leaner for higher altitude. That adjustment was traditionally out of the very top of the carb pointing straight at you. Screw it in(gently- it's not a wood screw). Then out 1/2 turn at altitude.
Jul 14, 2012 | Light Boating
My bread machine was unplugged with about 20 left in the bake cycle. How do I get it to go bake into the bake cycle. Display panel is unlit
If your machine has a "Bake" cycle then choos that cycle and push start and adjust the timer so it cooks the right length of time. Your manual should tell you how long the the last bake cycle takes and just push your timer until that time is set less the 20 minutes already baked.
Nov 05, 2010 | Oster 5834 ExpressBake Bread Maker
I need a manual for model BC-1691 Betty Crocker bake-it-easy brea
Hi
You can download the manual for your breadmaker from this link--
BC-1691 Betty Crocker bake user manual
Please accept the solution and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | Betty Crocker Kitchen Appliances - Others
Sunbeam bread maker loaf collapses in the center during the baking cycle. Cause??
Too much moisture, if measuring accurately try a little less, particularly if baking in high humidity on a rainy day. It takes a while to learn to adjust. If the dough appears to wet add a little flour while it is kneading cycle.
Mar 28, 2009 | Kitchen Appliances - Others
Bread falls in center when baking in Regal Bread machine. Am I ad
Hi, here are some tips
Go to this link then in the manual go to page 40 and start scrolling down.It has tips on checking your yeast and also what to do if your bread falls in the center.
Hope this is helpful
Kurt
http://www.scribd.com/doc/261890/Complete-Welbilt-Bread-Machine-Manuals#
Mar 16, 2009 | Regal Ware GL2850 Bread Maker
Breadman TR444 Bread Maker Logo
91 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Mike McBirney
Level 1 Expert
Irene Tulloch
kmciner
Level 1 Expert
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
