Have the machine's rotor assembly and door latch checked out as these two are the most common causes for no spinning.
If the machine has been making a loud noise when it was still spinning, the tub bearing could be at fault.
Your symptom sounds like a jammed drain pump. Was it spinning and then stopped before the spin cycle should have ended or did it not begin spinning when it should have?
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
