Question about Sennheiser Hdr120 Hdr-120 Wireless Headphone
Headphones only pick up next doors tv - Sennheiser Hdr120 Hdr-120 Wireless Headphone
    Top Expert:
  • Sennheiser Master
  • 10,875 Answers
Anonymous
SOURCE:
If I am using these headphones, can my wife here the tv without headphones?
If your headphones are plugged into the TV, then your wife may not be able to hear the TV. Take the headphones off and listen. If you can hear the TV with your headphones removed (only from your head), then so can your wife, bless her.
Couldn't you just ask her being as she may be sitting next to you?
Sep 07, 2017 | Televison & Video
I can't get sound through my headphones on my Bravia kdl-52xbr5 tv. First time I have tried to hook up the headphones which are sharper image wireless
I take it the headphones are charged up and known to be in good working order? Are you using the 3.5mm headphone jack on the side of the TV or the white and red RCA jacks labeled AUDIO OUT (VAR/FIX)? If using the headphone jack the TV should shut off the internal speakers and output to the headphones. If using the mentioned RCA jacks you need to go into the audio options settings and set to Audio System. Also under audio settings, Audio Out, you can pick Fixed or Variable. If you opt for Fixed you will use the headphones to adjust the volume. If you opt for Variable you can control the headphone volume and muting using your TV remote control. Just make sure you have the headphone volume turned up adequately.
Dec 16, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
Only picking up radio stations on headphones after plugging into tv audio
you have to go through the channels til u find the tv signal but the signal only goes to about 4 yrds
Sep 21, 2013 | Meridian Point 6 in 1 Wireless Headphones...
When I plug in headphones the tv, the sound still plays through its speakers and not through the headphones. How do I get the sound to play through the headphones?
Goto tv menu goto OPTION go to output select press the button pick Variable for outter speakers sound for input speakers or headphones.
Feb 04, 2011 | Dynex DX-LCD19-09 19 in. LCD TV
Super Boss FM HI-FI Wireless Headphone SF878 no sound from the tv
Hi - the tv sound will be picked up like an fm radio signal at 83 mhz. To get there, press the reset button the side of the headphones, then press scan. the first signal to be picked up will be the tv signal. This assumes, of course that you have fresh batteries in the transmitter and headphones, and that the volume is turned up on the headphones and the TV. Worked for me. The signal is not stereo, though.
Dec 30, 2009 | Televison & Video
RS120 Can still hear TV when headphones are on
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
Apr 08, 2009 | Sennheiser RS 120 Consumer Headphones
Sennheiser Hdr120 Hdr-120 Wireless Headphone Logo
209 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Ekse
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
