Linksys E900 Wireless N300 Router Logo
a
alubokho Posted on Mar 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am through which port do i connect the router linksys E900 to my laptop?
Through which port do i connect the router linksys E900 to my laptop?
Prashant M
Level 3:
  • Linksys Master 2,278 Answers
  • Posted on Nov 27, 2018
Prashant M
Linksys Master
Level 3:
Answers
2278
Questions
Helped
978458
Points
6246
There are 4 ethernet ports on the router. you can connect the laptop or desktop to any other 4 ethernet ports.
If your laptop has wireless feature then you can connect to the wifi network and you do not need to connect the Ethernet cable.
Check this link for https://fixhomenetwork.com/blog/linksys-e900-router-setup-and-review/
fixya62589
Level 2:
Novelist:
  • Expert 201 Answers
  • Posted on May 04, 2015
fixya62589
Expert
Level 2:
Novelist:
Answers
201
Questions
0
Helped
55785
Points
414
It's a wireless router, so you may not need to use a port at all.
You can connect to any of the ports numbered 1 through 4. The yellow Internet port should connect to your outside network. (Cable modem or router or Ethernet port from your Internet service provider.)
1 Related Answer
Anonymous
  • 1738 Answers
  • Posted on Dec 17, 2009
SOURCE: hello! My laptop is not able to connect to my Linksys router.
Make sure that your wireless is not secure or you are entering the right password. Also check to see what channel that your wireless is set on and compare that to your neighbors around you. If you and your neighbor have the same channel number set that is your problem. Your neighbor is over powering your own router.
3answers
I want change my liksys roter password E900.can any help me please My no is 0506327008
Linksys router is the best network service provider between another router service provider, there are features provide high-speed internet, multiple connectivities, easy for installation and etc.
To troubleshoot Internet connectivity issues:
First of turn off your router and connect modem directly with your computer.
Login your router by following login manual steps.
Click the Smart Wizard Test button to access the NETGEAR online test page.
Under Router Status, and check your router has a valid IP address. For more information, see your router user manual setting.
We have very expert technicians who always ready for the solve technical problems, the customer connect with us by dialing a toll-free number. Our service is available 24*7 for the customer who faced some technical issue with router contact Linksys Router Phone Number by dialing toll-free number for the other service visit service number website and get solutions.
https://servicenumber.org/linksys.html
Jul 10, 2016 • Cell Phones
What is Router name or SSID
It is what the router broadcasts so devices can find the connection. For example, when you are using a laptop or smart phone you can check for available WiFi connections. The SSID for all connections in range will be listed. The SSID enable you to find your router on the list.
My E900 router disconnect internet every 6 hours, what can ! do ? thanks
You could try to login to the router and check the WAN connection, ensure that the connection time to idle is set at '0', this will make sure that it is up all the time.
1helpful
2answers
Where do I find the password for e900 router?
On the E900 router, after a factory reset, the IP will be 192.168.1.1, with a default password of "admin" and no username.
Hope this helps,
Danny.
1helpful
How to find my forgotten password on linksis e900
Google-search "reset Linksys e900" to restore it to "factory" settings, including the original ID/password. Then, start over to setup/configure your router, including setting a new password.
How do I connect a verizon 4620L to a Linksys E900, w/o wire connections? I have successfully conected both to my Laptop, but cannot access the internet through the E900.
Both devices have a DHCP router built into them so on the second router the E900 you need to log into the administration page and disable DHCP. You may also need to hardcode the ip address of the E900 to an IP address in the range that the 4620 uses.
You will probably have to name the E900 wireless name to be the same as your wireless hotspot name so your devices will switch between the 2 depending on the one with the best signal.
I am guessing you are using the E900 as a wireless extender in another part of your house so you have good coverage.
How to connect the linksys RT31p2 router to the laptop with vista software
Use LAN cable and connect it to your laptop, the other side to one of the LAN ports in router
I have the 4 port Linsky Router.I have a Sony laptop connected to a Sony wireless routerI also have a movie download box. When I connect both to the modem separetely,bolth the laptop and the mvie download...
this is because your wireless router is a router, and your linksys is also a router. Both are attempting to do routing, and they're colliding with each other.
Go into your linksys router's settings, and set it's IP address to have the SAME subnet mask as your wireless router, (The third number in the ip address has to be the same)
e.g. if your wireless router is 192.168.0.1, make sure your linksys is 192.168.0.2
if your wireless router is 192.168.2.1, make sure your linksys is 192.168.2.2
After that, turn OFF the dhcp server on your linksys router (do this in the linksys config page).
After that, plug the LAN port of your linksys to the LAN port of your wireless router.
Your linksys will now be acting like a "Switch" which is an extension of your network. Voila!
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
