There are 4 screw holes but no screws and they are not a standard size thread? Help
The thread size is standard, just a metric standard. To attach the Sylvania LCD427SSX to the wall mount bracket you'll need (4) metric 8mm machine screws with a 1.25mm pitch. You'll find them at your favorite neighborhood hardware store with the designation M8 1.25x40mm. (40mm long...the 30mm would be to short)
Go to home depot and ask for the following:
4 M4x30mm Machine screws; 4 M4x12mm Machine screws; 4 M4/M5 Flat washers. I hope this helps.
I had the same issue with a Sylvania model LD320SS1 and it too took the M4 (4 mm) metric screws as noted above. For my TV the M4x16 mm long was perfect. After buying the screws, I discovered the screws that were provided to attach the table stand to the TV were the same screws needed for the wall mount. The Owner's manual does not mention that.
