Most likely it is the motor position sensor also known as a hall sensor. very common issue on older lg washers. easy fix, inexpensive fix--$20. check out appliancepartspros.com or repairclinic.com for excellent videos on how to replace. type in make/model and you will find videos. replace with oem/lg part. do not get oem equivalent part. good luck.
1. please do restora factory settings, the default code is 12345.
2. if u r unable to do that then go to nokia care and flash ur handset.
