Washer sounds like a jet airplane taking off during spin cycle. Could this be bad bearings?
I had a Maytag washer almost 5 years old that sounded like a Jet Engine taking off during the spin cycle. It was the Tub Bearing - there are kits to do this yourself. To hire someone it would of cost almost as much as it would be to buy a new Washing machine. Never again Maytag - it was whats inside that mattered so I bought an LG washer.
If you let it go too long your going to wind up flooding underneath the washing machine with Brown gunk
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Yes it is more than likely the main bearing due water leaking into the bearing from seal failure. You need to replace it as a kit if this is the problem. You should also check the holes in the inner bowl sometimes a nail & bra wire can cause the same noise.
SOURCE: Neptune washer load noise.
I do know there is a set of bearings on the drum drive shaft. There is an inner and an outer. Some places mention that these bearings are no longer available. However, I found on ebay a gentlemen who sells these bearing and the seals in a kit for about $80.00. It comes with instructions on how to repair and will save a lot of money. I have done this once already to the same washer, now I am doing it again. If you search on ebay maytag neptune parts you will find his listing for a bearing kit. He also describes the jet engine noise.
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
SOURCE: Very loud noise during spin cycle
Probably a broken strut or support. some call it a shock absorber.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: machine making a squeaky noise when washing and
this sounds like the drum bearings and or the drive belt wearing out
SOURCE: Spin cycle makes jet airplane takeoff noise.
Bearings do exist but need a special puller to remove. If techs i n your area have it part numbers are 22002934 , 22003441 also needed is spacer 22002935 and seal kit 12002022 or else you need to order the whole outer basket
