Most tablets are minimal for content. There are some good resources on the Internet that will answer your questions. Here is an example of one that came up with a google search on ' how to use android tablet ': http://www.dummies.com/how-to/consumer-electronics/Android-Tablets.html
Hello, today I will show you how to fix stuck on android or remove password, for model SC-91JB - SC-74JB
First, connect your tablet to PC.
you need drivers to be able to reset;
download the adb drivers from website; www.adbdriver.com/downloads/ or click on link below for direct download. ADB Driver Installer (9.22 MB) next, install the ADB driver then you will see a USB root on notification area on your PC.
next, download the fastboot click on link below; https://www.dropbox.com/s/adu0ysny2191kgd/Fastboot.zip?dl=0
install fastboot and you will open a dialog box.
Follow the steps on image below; step one, two and three...
next, command prompt will open and you need to type these commands;
This will reboot and erase password.
If stuck on Android; type commands below (it's the same way like on top image just shorter commands).
Typicallyu you can turn the tablet off. Tap the power button then press and hold either power + vol down or power + vol up until you get a menu. Navigate to Factory Reset.
You will need to do a factory reset: 1. With the device off, press and hold Volume Up and Power. 2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears. 3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection. 4. Press Volume Up continue.
When the tablet is OFF hold volume up button then switch on all the time holding the volume up button untill it boots into reset options. use vol up and down to scroll between options then power button to select.
