On my iPad it just says ipad error id003 not activated but I have activated it and it still won't work.
SOURCE: issues with my Ipad wifi, IPAD wifi not working
According to Apple, the iPad might not automatically rejoin known WiFi networks using third-party routers that are dual-band capable (802.11 b/g and 802.11 n) when each band’s network uses the same name or use different security settings.
Apple’s recommendation? Try creating separate network names for each separate band’s network (ie: add a G to the end of the name of the 802.11 b/g band) and making sure both bands’ networks use the same security settings.
SOURCE: 3g not working on apple Ipad
As far as I understand it the ipads that have just been released are wifi only. 3g are available from late April, see the www.apple.com for details.
SOURCE: Apple Ipad screen isn't working
If the issue persists after a restart, there may be an issue with your digitizer / touch panel. Apple willhelp you with this because it is so new. However if you dropped it in water (etc.) and if apple doesn't replace it for you, You can get the digitizer at iPad Repair and there is a guide that shows you how to put in the part at Electronics Repair Guide.
Testimonial: "thanks"
SOURCE: I purchased an ipad in
The device that you bought is not an 'iPad'. It's actually a 'tablet'. iPad is the tablet manufactured by Apple. Now for your tablet... do a manual search for the product on the company's website. Anyways, Android is very intuitive and easy to work.. so just play around with the device for some days and you will find out how things work. If you still have some issues, post it here on fixya.
SOURCE: Can't charge the ipad from the USB charger
To get Ipad to show as charging download Asus AiCharger from web and
restart computer after install.Plug in usb from Ipad and should now show
charging
http://event.asus.com/mb/2010/ai_charger/
Please Rate
