Brother HL-2040 Laser Printer Logo
Posted on Jul 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Brother 2170w with all lights flashing. Turning on and off does not fix problem. Help!
  • andrewbray Jul 09, 2009
    I don't know - I think a power interruption - but I got it fixed with a suggestion from someone else. thanks.
  • Anonymous May 11, 2010
    What happened before the light started flashing. Is there paper jammed?
Anonymous
Level 2:
  • Expert 126 Answers
  • Posted on Jul 10, 2009
Anonymous
Expert
Level 2:
Answers
126
Questions
0
Helped
60829
Points
365
This is in reference to another solution on this site--please search before posting as others have already solved this problem:
Per http://www.fixya.com/support/t2462964-all_3_error_lights_flashing_4_count_go
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
2answers
I fixed the drum and error light but i still can't print
http://mycomputerbytes.wordpress.com/2011/11/16/reset-brother-hl-2170w-network-settings/
If printing via network and you have not set a static (meaning it doesn't change) ip setting for your printer, then your ip address may have changed. IF this is the case, http://mikebeach.org/2011/03/02/assigning-the-brother-hl-2170w-a-static-ip-address/
Also, have you updated your printer driver? Be sure to go to control panel, device manager, printer, and then uninstall before installing new driver. Also, uninstall/remove the printer.
http://support.brother.com/g/b/downloadtop.aspx?c=us&lang=en&prod=hl2170w_all
Hope this helps.
My brother HL-2170W have a flashing error and drum light. When the printer starts up, its stops in the middle as if a paper is stuck but I can't find anything.
Hi There,
The Drum LED and the Error LED alternates turning on and off.
Meaning of LED Indication
Drum error:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Please click on YES if this helps,
Thanks,
Vikroks
14helpful
My HL-2170W has a flashing drum light and won't print. I replaced the drum but still having the same problem. Now what?
To reset the drum message:
Open the front door
Press and hold down the white button for about 4 seconds.
Once all 4 LEDs are lit, release the button.
Close the front cover.
Make sure that the Drum LED is now off.
complete instructions can be found here
20helpful
Drum light flashing on brother printer hl-2170w. what needs to be fixed?
Open the front door
Press and hold down the white button for about 4 seconds. Once all 4 LEDs are lit, release the button.
Close the front cover. Make sure that the Drum LED is now off.
2helpful
I relaced the drum yesterday on my HL-2170W but the drum light keeps flashing - how do I get it to remain off?
Open the front door
1helpful
3answers
1helpful
3answers
My Brother HL 2170W printer has red error light on. It was printing something over and over and I wanted to stop it so I pulled (oh, no!) the paper out and then I guess the red error light went on. I...
There is probably still part of the sheet in the fuser at the back of the machine. The fuser will need to be removed and checked for scraps of paper and/or damage to the temperature sensor and v likely a dislodged paper sensor arm.
2answers
Lost cd-rom for brother HL-2170W. I need to connect a new laptop to the printer on my wireless network and can't figure out how to do it! It's running Windows XP Pro.
Download the updated firmware, drivers and software for you printer from here (select 'ALL' as Type, and then select your OS and language, to see all downloads available in one page):
Brother HL-2170W downloads Homepage
Also download the manual and guides for your printer:
Brother HL-2170W manuals
And make sure you also look through the FAQs and Troubleshooting under 'Initial Setup' and 'Software' sections:
Bother HL-2170W FAQs & troubleshooting
5helpful
2answers
All 3 Error lights are flashing (4 if you count the GO button)!!
Norman Weimar
Norman Weimar
k24674
