Harman Kardon AVR 630 Receiver Logo
Ronald Brown Posted on Mar 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reset my harman/kardon avr 630 receiver ?
Pyrophore
Level 2:
New Friend:
  • Expert 35 Answers
  • Posted on Mar 19, 2015
Pyrophore
Expert
Level 2:
New Friend:
Answers
35
Questions
0
Helped
29524
Points
131
See link for users manual. Instructions for Processor Reset are on page 50.
"Processor Reset
In the rare case where the unit's operation or the displays
seem abnormal, the cause may involve the erratic
operation of the system's memory or microprocessor.
To correct this problem, first unplug the unit from the
AC wall outlet and wait at least three minutes. After the
pause, reconnect the AC power cord and check the
unit's operation. If the system still malfunctions, a
system reset may clear the problem.
To clear the AVR 630's entire system memory including
tuner presets, output level settings, delay times and
speaker configuration data, first put the unit in Standby
by pressing the Standby/On Switch1. Next, press
and hold the Surround Mode Group Selector2
and the Tuning Mode Selector8buttons for three
seconds.
The unit will turn on automatically and display the
RESET message in the Upper Display Line #.
NOTE: Resetting the processor will erase any configuration
settings you have made for speakers, output
levels, surround modes, digital input assignments as
well as the tuner presets. After a reset the unit will be
returned to the factory presets, and all settings for
these items must be reentered.
If the system is still operating incorrectly, there may
have been an electronic discharge or severe AC line
interference that has corrupted the memory or
microprocessor.
If these steps do not solve the problem, consult an
authorized Harman Kardon service center."
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0CCwQFjAE&url=http%3A%2F%2Fwww.harmankardon.com%2Fimages%2Fmedia%2FAVR630_OM_EN.pdf&ei=HjALVeKILsyrNtyXg6gF&usg=AFQjCNG_sg9tBR5xnCJ4wxQ5ilVYI3RSfQ&sig2=kPcGUIhiWGqVexx8yZMpzQ&bvm=bv.88528373,d.eXY
5 Related Answers
Anonymous
  • 1512 Answers
  • Posted on Jun 29, 2008
SOURCE: How to I reset my
Hi odysy
I got this from the manual page 43.
Resetting the Remote Memory
As you add components to your home-theater
system, occasionally you may wish to totally
reprogram the remote control without the confusion
of any commands, macros or ”Punch-
Through“ programming that you may have done.
To do this, it is possible to reset the remote to the
original factory defaults and command codes by
following these steps. Note, however, that once
the remote is reset, all commands or codes that
you have entered will be erased and will need to
be re-entered:
1. Press any of the Input Selector buttons 4
and the ”O“ button Hat the same time until
the Program/SPL Indicator 2begins to flash
amber.
2. Press the ”3“ button Hthree times.
3. The red LED under the Input Selector4
will go out and the Program/SPL Indicator
2will stop flashing and turn green.
4. The Program/SPL Indicator 2will remain
green until the remote is reset. Note that this may
take a while, depending on how many commands
are in the memory and need to be erased.
5. When the Program/SPL Indicator 2goes
out, the remote has been reset to the factory settings.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Anonymous
  • 13 Answers
  • Posted on Nov 26, 2008
SOURCE: Harman Kardon AVR 135 6.1....AUDIO DELAY???
This model does have a delay function. Programming is on page 19 of the user manual. Go to http://www.harmankardon.com/product_support/interstitial.aspx?sJump=ps&Region=USA&Country=US&Language=ENG select all products, AVR135, and get the owner's guide. If you have trouble with the link, then go to the Harmon Kardon site, and make your way to the support portal and then select all products.
Anonymous
  • Posted on Dec 28, 2008
SOURCE: My Harman Kardon receiver (
I used the live chat and the problem was resolved.
Usually the problem are strands of speaker wires which cause shorting and protection shuts off the receiver in order to prevent damage. There was one speaker that I repositioned recently which was causing shorting. I twisted the wires and tightened them in place and my receiver has been working w/o a glitch. I was lucky that I did not have to check all the wire strands on the receiver and all the speakers.
Problem solved and I learned valuable lesson.
Anonymous
  • 382 Answers
  • Posted on Jan 01, 2010
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Testimonial: "cheers, have a good year."
Anonymous
  • Posted on Feb 12, 2010
SOURCE: My Harman Kardon AVR 330 is locked. Can't unlock
youtube
myspace
facebook
Harman Kardon AVR 630 8CH mode not available
According to the Harman-Kardon AVR 630 User Manual, if the 8CH mode is not available, you can try unplugging the unit from the AC wall outlet and waiting for at least three minutes. After the pause, reconnect the AC power cord and check the unit's operation. If the system still malfunctions, a system reset may clear the problem. The 8CH may not be available according to the user manual. You need to contact Harman-Kardon customer support.
Harman kardon avr 3600 no signal after firmware update..i think the firmware only got partial install
Try resetting the processor follow the link this will tell you how to do it.
https://www.manualslib.com/manual/278933/Harman-Kardon-Avr-300.html?page=38
How do i reset an harman kardon avr-310
There is no reset for it, If it doesn,t stay on something is wrong with it,End it has to be taken in for repair,
Hi, i am having problems with the multiroom on my AVR 630
Go into your OSD (on screed display).
Go to multiroom.
Change the SB AMPS from MAIN to MULTI.
Make sure you have only analogue sources, it will not amplify digital inputs for the MR.
3helpful
2answers
I have Harman kardon AVR 630 and I have trying upgrade for better performance but during the upgrade the problem occured. I have contacted the harman service it seems a lot of money required.
If it failed during the upgrade after it flashed the memory and before it reinstalled the new firmware it has to go in for service. And it will be over 100 USD. est.
Harmon Kardon AVR 630
I ever had this problem, so I contact the service center and they re-program all setting. So,would you like to ask the nearest service center.
Top Harman Kardon Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Sean Wright
Sean Wright
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
