I
Ian Gabsch Posted on Mar 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Has a lsu error - SCX Samsung Office Equipment & Supplies
sahoo_sanjay
Level 3:
Master:
  • Samsung Master 553 Answers
  • Posted on Mar 18, 2015
sahoo_sanjay
Samsung Master
Level 3:
Master:
Answers
553
Questions
0
Helped
219029
Points
1676
Dear Ian
Pl. open the LSU and clean the optical path and polygon motor with a dry cotton lint free cloth. If not resolver then replace the LSU.
Thanks.
LSU error shown how to resolve the problem
Dear
The LSU error may be due to the failure of following
1- harness between lsu and main PBA.- repair/replace the harness.
2-lsu itself-clean optical path inside lsu with dry lintfree cotton cloth.
3-Main PBA- replace the main board.
Thanks.
6helpful
2answers
How to troubledhoot the LSU error on samsumg
repalce laser unit or check menu # 1931 lsu mirro test
1helpful
My printer have a LSU Error so what i should do
check your printer inside for RAT damage,
this error ocured when lsu cable cuts by rat or LSU itself faulty
Display reads E-7 03 error code
E7/03 is a lsu error. The LSU is the “printer head” of the printer. But instead of emitting ink, the LSU emits a laser beam, directing it at the drum of the toner cartridge. If replacing the lsu does not fix it it may be the mcu pwb, but most likely the LSU.
6helpful
4answers
Engine LSU error printer model samsung ML2150
how can over come from LSU error problem in samsung all in one machines
1helpful
3answers
Have lsu error also.
Hi ...
LSU stands for Laser Scanner Unit ... you normally get 2 different kind of errors with LSU ...
LSU Hsync or LSU Motor Error ...
If you get this error, it means that the Laser Scanner Unit has gone bad and the only way to get it fixed is to get the printer repaired ...
Cheers ....
3helpful
29helpful
3answers
5helpful
Error LSU
The LSU error stands for Laser Scanner Unit error. The probable cause/s:
The Polygon motor in the LSU does not rotate.
The LSU’s laser beam is functioning properly.
What you can do:
Try to unplug the machine for a couple of minutes or maybe a little longer and then plug everything back in. Power on and then test.
18helpful
4answers
Lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Thanks.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
