Question about Husqvarna Forest & Garden 125l 18" Gas Trimmer
How to string a weed wacker - Husqvarna Forest & Garden 125l 18" Gas Trimmer
    President:
  • 1,126 Answers
4 Suggested Answers
6ya staff
SOURCE:
#1 Taper
Jim Parker
  • 1041 Answers
SOURCE: How to change the string
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Posted on Jul 03, 2009
Anonymous
  • 163 Answers
SOURCE: weed wacker
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 28, 2008
Anonymous
  • 3 Answers
SOURCE: How do I restring my Ryobi weed wacker
Start in the center ,snap the center in place. than put the ends out through the holes.
Posted on Jul 20, 2009
Worx electric grass trimmer / edger wg116 restring. Need this one not 117.
Demonstrated on a Worx String Trimmer - YouTube
? 3:55
www.youtube.com/watch?v=fFt3a3St54U
Jul 9, 2014 - Uploaded by EricL5150
This is a video on how to replace weed wacker string trimmer line in a string trimmer/weed wacker. ... This is done on a Worx string trimmer but the process is pretty much the .... How torestring dual-sided spool lawn weed eater trimmer with ... Worx56volt Cordless Trimmer Edger Review & Demo Video ...
Sep 18, 2015 | Worx Garden
Help my weed wacker string
Pull the spark plug out and try pulling it over if still won't move might have seized the motor possible not enough oil in gas You can try if not to much damage done pour some kerosene or stove oil down spark plug hole let sit over night try again
Jun 08, 2013 | Garden
The line on the B & D Electric Weed Eater has broken off. I can take the Orange cover off, but I do not know how to get the spool so I can continue weed eating.
Not avoiding the answer but if you google (" re-string a weed wacker video?" ), you can watch a video of how to do it, which may be a lot easier to understand when you see it.
Jun 30, 2011 | Black & Decker Vacuums
Have a Ryobi weed wacker 725r 31cc click link Trimmer Plus. No more line-can't figure out how to remove bottom to replace the line or what kind of line to replace with. Deceased husband lost directions...
i also have a ryobi weed wacker. if it is the same. you don"t have to remove the button. line up the 2 arrows one on wheel with bumpy edges and one by the button. you should see 2 holes feed a 2-3 foot piece of line into the hole the line comes out of for cutting and it should come out of a curved holw on the bottom by the button .tuck the end into a small round hole . pull line tight (tug on the section that you cut with). wind the string by turn the ring around the button. til desired length. if this doesn't work. google you model # and look for a manual (manual for ryobi weed wacker model # ------------.)
Jun 09, 2010 | Garden
Wind string on Spool
Most weedeaters have an arrow on the spool. Look at both ends, you'll probably find the arrow. Put your line into the hole and wind the line in the direction of the arrow until you have enough loaded.
Sep 04, 2009 | Garden
McCulloch mt 700 weed wacker,the weed wacker will not spin to cut the weeds
If the motor is running another possible solution is you have a broken drive shaft spring PN-753-04280 To check this remove the screw which holds the **** pipe to the motor and loosen the clamp. The **** pipe should pull right off the motor exposing the end of the drive shaft spring. Pull the end of the spring, if it comes out it is broken.
Jul 06, 2009 | Garden
I cannot figure out how to open and respool the string on my mod 2816 mc culloch weed wacker and i do not have a manual.
I stopped in at a local lawn mower/small engine sales and repair shop and asked them if they could help me and they told me what to try before i brought it in to have them fix it. Their information proved to be very helpful and they saved me the trouble of bringing the weed wacker in. I now can reload the string myself.
Jun 12, 2009 | Garden
How do you put the weed wacker "string" in mine keeps flying out when I rev it up to weed wack
You need to give close attenttion to the string wrap" arrows" or guides and see if there are holes the size of the string your using is correct size to fit into these "grip holes inside the casing.
Please rate
tk u
JJ
Mar 17, 2009 | Ryobi Garden
Double spool on Weed Wacker
This isn't a solution to the problem. However, I think you should talk to someone at Home Depot or Lowes or wherever you bought the model, and see if the string is in there correctly; if it is, then u'r weed wacker must have some other mechanical problem. Sometimes it is just best to buy a new one. The more expensive models are the best.
Aug 10, 2008 | Electrical Supplies
Husqvarna Forest & Garden 125l 18" Gas Trimmer Logo
912 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
