Drain pump: rinse+spin drains the tub, ~14ohms on the coil. No lint build up on the stator. Circulation pump: appears to pump water up to the top, ~27ohms on the coil. I did clear the circulation hose of obstructions but this did not resolve the issue. Is there anyway to test/reset the main PCB?
It's probably your cold water input solenoid assembly.
even if the solenoids are working fine, there is probably physical damage inside the flow restrictors allowing too much water into your unit during drying.
try turning your cold water valve almost complete off, down to just a trickle.
if your wash completes without errors then the input solenoid assy is definitely at fault.
The drain pump and circulating pump coil resistance readings are within the acceptable ranges.
Run the machine on the QC Test Mode according to your user manual, also check the Water Level Frequency reading during this test to see whether it falls within the normal range according to the manual.
Look inside unit for tech sheet, technician manual to run diagnostics mode. See if you can find stored codes and it should also tell you how to erase stored error codes.
