SOURCE: Scratchy and distorted sound in media player
There are a few possible reasons for this.
1. Your drivers are bad, look for new updated drivers from vendor and from windows update.
2. Your system is under heavy load and has trouble playing sounds, you can try to close not needed programs from the taskamanager.
Also, download process explorer http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx'
after extracting the program from the zipfile pay close atention to what is useing the CPU take note if INTERRUPTS / HARDWARE INTERRUPTS or DPC's / Deferrend Procure Calls are happening alot. This can be a sign of hardware problem or complex windows problem. In this case I would recommend reinstalling windows. If the problems continue it is most likely a hardware issue.
If INTERRUPTS and DPCs are normal between 0 and 50, for short perioids, can be higher, but if constant high values then this is a problem.
If those two are not a problem go thrue all applications and find out witch is eating all the cpu, when found try shuting the program down by pressing delete after selected on process manager.
If these dont solve the problem I'l type more later.
SOURCE: acer aspire 5620 touchpad problems
Go to acer website and look for support/then driver download/select your model/and download/do RUN instead of SAVE
SOURCE: Distorted / skipping sounds from Acer laptop
Go to the sound icon which is at the right hand bottom corner on your task bar, explore properties cheack wheather voice supression is any thing else than 0.As well as check for enviroment.
SOURCE: Acer Aspire 6530 Sound Distortion
First thing to try is updating your sound driver.
Visit Acer's support page, find your model, download the software, install. test.
Let me know what happens.
SOURCE: my subwoofer sound is distorted
whatever player are you using must be having Equalizer in it...try adjusting that [keep that down to a minimum]. Check the program for your audio device...some programs have sound options like jazz,rock,pop these are predefined equalizer changing these could also help. Try using a different media player like VLC [it's free to download on the web] Try uninstalling the audio driver and then reinstalling the driver. It is quite possible that your speaker doesn't match with the Laptop's amplifier or the speaker is gone kaput [a coil problem or something needs repair...but do not repair rather buy a good speaker coz repairing loses the quality].
