(sounded like a fan), for an evening. Now the contents of the freezer are defrosting. The fan does not seem to be running, and the was a red indicator lit on the panel. There is a faint electrical burnt smell. Has the fan burnt out? Would this affect any other components, and why should this happen?
The fan only controls air circulation. not the function of the motor. sounds like ur fridge is stuck in the defrost mode? check ur cold control thermostat with a multi meter for continuity. the fan does not run while in defrost mode, u can manually check ur defrost timer in the fridge by sticking a small screwdriver into the hole underneath it, and turn clockwise till u hear a click u should hear the fan and compressor come on if not turn 1 more click?
Testimonial: "The bottom was still cold. The circ fan was not running. I have replaced it. The old one gets hot and the bracket had melted and deformed causing the fan to stall on the surround. Thanks for the suggestions."
SOURCE: GE ADORA DSS25KSRDSS FREEZER FAN NOISE
Unplug your unit and check the fan blade by manually rotating it with your finger, check if the blade is not touching the fan blade frame. Check if the screws are not loose, align the fan blade and re tight the fan blade screws.
SOURCE: Freezer not freezing, water in freezer
The frige may be stuck in defrost mode. If the compressor and condensor fan are not running then it is likely in defrost mode. If the compressor is running continuously then there may be a leak in the sealed system where the refrigerant is low or gone. There is a tech sheet located in the very bottom area of the frige (behind the lower vent and in a plastic holder usually). Pull that lower front vent off and use a flashlight to find the tech sheet for any troubleshooting help and were the defrost timer is. Sometimes you can use a flat blade screwdriver to advance the timer past the stuck spot and get it working again. As for checking for a sealed system problem you would need to pull the back wall cover off the freezer section to view the coils. Normal frost pattern would be all the coils covered with a light white frost. If the frost pattern suddenly stops and bare aluminum coils are showing there may be a plug or leak in the system. It's not too often that the new thermistors (your thermostat control) go out. To check you could short across the t-stat to see if you can force a compressor run or take the leads off the thermistor and check the ohm value with a multimeter.
SOURCE: whirlpool refrigerator making noise
YOU HAVE AN ISSUE WITH THE DEFROST CIRCUIT. NORMALLY BOTH THE DEFROST COMPONENTS NEED TO BE REPLACED. NOT OFTEN DOES THE DEFROST TIMER GIVE TROUBLE SO IF BOTH COMPONENTS ARE REPLACED AND ELEMENT IS GOOD BUT ICE STILL BUILDS UP THEN TIMER WILL HAVE TO BE REPLACED AS WELL.
SOURCE: SIDE BY SIDE Frig & freezer
hurlsdad.
Sounds like a noisy evaporator fan. Take the shelves out ot the freezer then take the panels on the back wall of the freezer off. The fan will be there. Then you will know for sure thats the source of the noise. When it is time to replace it...easy fix. (few screws) Here is an excellent source for the part..www.repairclinic.com. My favorite place for appliance parts.
hope this is helpful,
handiman518
SOURCE: red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In
a no frost refrigerator, the defrost timer activates defrost heaters in
the evaporator section (rear of freezer) which heat up and melt the
frost off the evaporator coils. This process lasts for approximately
25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the
heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Usually when the fan in the freezer is making noise it is because there is ice built up and it is hitting the fan...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
