Question about Astoria Divina SAE-2 Coffee Maker, Espresso Machine
How are the 2 lines from the pressure gauge supposed to be hooked up to the tank? We just bought this machine and cleaning it up when we noticed the 2 lines coming from the gauge but only one line (the left one) goes down and is connected to a line across the bottom. The line on the right side of the pressure gauge is not hooked to anything but is zip tied to a piece on top of the tank that the steaming wand line is hooked up to. Why would it not be hooked up? Also in the group head, how do you get the hex looking thread or bolt/screw out of the head?
    President:
  • 1,618 Answers
One of the lines is for pump pressure and lines up with the side that reads 0-15, that would be the one leading to the bottom of the machine. The other side is for steam pressure which reads 0-3 that is connected to the boiler. As for the grouphead if the screen is in place you should be able to use a 5mm allen wrench if that is what the screw head is, which is someone changed it from a flat head that is what they put in.
Posted on Jul 28, 2015
5 Suggested Answers
Anonymous
SOURCE:
z34aga
Sulejman Sulejmani
  • 137 Answers
SOURCE: I need a new pressure guage for an Astoria A2 - coffee machine
here is the site where you can get your presure gauge and other parts for your machine.http://www.espressoparts.com/results.cgis?catalog=&select=NAME&keywords=astoria+pressure+gauge&image.x=15&image.y=14
Posted on Mar 30, 2009
EsWorld
Ernest R
  • 1618 Answers
SOURCE: I have boiler pressure and steam coming threw the
Either the solenoids are damaged or blocked, or the metering jet on the top of the group is blocked, or the blockage is at the flowmeters. Do you get a reading on the pump pressure gauge when the buttons are pressed?
Posted on Jun 02, 2011
EsWorld
Ernest R
  • 1618 Answers
SOURCE: how to fix the wand
First check the steam wand tip to make sure it is not blocked. If it is clear remove the wand and run it under a faucet to make sure it is not blocked, it water flows freely, then the problem is on the fitting that connects the valve to the boiler, remove fitting and check, if clear check the boiler fitting, use a screwdriver and clear the fitting on top of the boiler.
Posted on Jun 28, 2011
Solamente
Solamente
  • 15 Answers
SOURCE: I replaced the pump and it's working, however, when I turned on the machine and the boiler came up, there's a stream of pressured steam coming out of releasing through the top of the machine. Any id
Hopefully, your pressure gauge is working, and if it is at 1.2 bar or so, then you have a failed anti-suction valve or boiler safety valve.
The ASV is the smaller fitting; it might be stuck, so you could try tapping the little button. The boiler safety valve is another matter - it will open at some point past 1.8 bar, which means the pressurestat is shot or its adjustment has been tampered with.
25401838-vippk3d42tdcmss1ngrlvpy2-1-1.jpgBoiler Safety Valve
It's most likely the ASV - they do get stuck open as well as closed...
Posted on Feb 06, 2015
Gauges show 90 psi but can,t inflate car tires past 10 psi
A lot of compressors today have a regulator where the hose hooks on ,Most times there is two gauges on it, one is tank pressure and the second is line pressure, and a knob to twist in and out to increase and decrease line preasure. Air Compressor Line Setup and How to Use Air Tools for Beginners
Mar 23, 2016 | Psi Air Tools & Compressors
Changed oil pump still low oil pressure 2004 twin cam
First off, if you are going by the idiot light, it COULD be a bad sending unit.
Either replace with a new one and check again, or hook up an oil pressure gauge (At 2000 RPM you should have 30-38lbs) to get a more accurate reading:
http://www.harborfreight.com/160-psi-dry-gauge-68249.html
IF is is still ACTUALLY low, pull the relief valve spring and make sure its clean and nothing it blocking it from seating correctly.
A cracked cam plate could also cause a loss of oil pressure.
Finally, make sure that the oil line fron the oil tank to the pump (feed line) isn't plugged.
Dec 28, 2013 | Harley Davidson Motorcycles
HS 80 it seems that when the primer bulb is pumped it pressurizes the tank and will not strrt
First, it helps to understand what the primer/purge bulb is SUPPOSED to do. It's only purpose is to bring fresh fuel from the tank to the carburetor and push any air and old fuel in the carburetor back to the fuel tank. The fuel lines should always be pretty much full of fuel (the retun line will have fuel and air in it).The purge bulb does NOT have to be completely full to work properly.There are also very small check valves in the carburetor near the purge bulb that allow the fuel to flow in the proper direction and not backflow. Sometimes, they go bad or get stuck. This may have happened in your carb, or there is a blockage somewhere.Air and old fuel going back to the fuel tank the way it is supposed to does not pressurize the tank.Also, the tank is supposed to be vente (look for a small black piece called a duckbill under the tank cap). Make sure it is clear and clean. Check all fuel lines for blockage or debris. Sometimes, the lines themselves deteriorate from the inside-out and it is hard to notice until problems like this occur, If you want, remove and check ALL the gas lines. Remove the purge bulb and spray liberally underneath it with say WD-40. It sometimes cleans and clears the check valves.Try all these remedies and post back. I will see your comment and reply.
May 10, 2011 | Echo Garden
I just bought this unit took it home read the instructions loaded the gun with nails hooked up the cables opened the gauge turned on the unit and i waited for the tank to fill with air and the gauge...
There are usually two gages, one for the pressure in the tank, the other is for the regulated pressure in the hose going to whatever tool you have connected. I assume the tank filled up and the tank gage registers pressure in the tank. When you said you "opened the gage" I am guessing that you turned the knob counter-clockwise which would be the normal direction to open a valve. However, this is not a valve, it is a spring loaded regulator device. When you turn the knob counterclockwise you are removing all pressure from the spring which sets the regulator to allow zero pressure in the hose. Turn the knob clockwise to increase the pressure in the hose. I hope this was helpful. Good luck.
Feb 18, 2011 | Porter Cable Air Tools & Compressors
How to replace a craftsman weedeater gasline?
you hook one line to it the return line inside the tank
The line you used as a return line pull it back thru the gas cap hole and put that piece on one end of that line and pull it back in the tank until it stops and then hook the return line back where it belongs
May 14, 2010 | Craftsman Garden
I bought a new tank for my reverse osmosis water treatment and it did not come with directions. It's supposed to be ''charged,'' whatever that means. When I hook it up to my system it does not fill with...
Typically a reverse osmosis storage tank should have a precharge of approximately 7 psi. Depending on the make/model of your tank it may have a higher charge currently which would cause the tank to not fill. There should be a schrader valve on the bottom or side of the tank. Using a tire gauge and bicycle pump you should be able to check the current pressure in the tank and adjust it up or down to 7 psi.
reverse osmosis storage tanks: http://www.freshwatersystems.com/c-32-reverse-osmosis-storage-tanks.aspx
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Nov 04, 2009 | General Electric FX18M GE SmartWater...
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
What is the range that the fuel lines should have when hooking up a fuel pressure gauge to the fuel lines on a 2001 chevy s-10 ZR 2
You want to make sure you are hooked up to the pressure line. This is the larger of the two lines. Depending on the engine pressure is in the vicenity of 29-36 psi or can be 9-13 psi. The fuel pump is in the tank and these trucks have wiring issues.
What is your exact problem?
Jan 15, 2009 | 2001 Chevrolet S-10
Fuel lines
usually there where 3 lines from the gas tank one is the breather,main line,and the reserve line..just try to trace the line
Sep 01, 2008 | 1996 Oldsmobile Achieva
Astoria Divina SAE-2 Coffee Maker, Espresso Machine Logo
93 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
NOEL
NOEL
Vitally Alcher
markybean
Level 1 Expert
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
