this is not a thought I am 100% sure and give you the
correct solution:
problem with the paper feeding section is dusty or due to developer
drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and
drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner
collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a
complete unit
included paper feed rollers motor and clutch and gear section)
7. Clean the
drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now
fix it all
10. replace developer unit bush witch are faulty or if you
don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer
drooping on the gear
I'm facing the same issue. did you find any solution to solve this ?
i solve the problem by reseting the head printer and remove all ink cartridge then
putting them back.
Hi - what is "resetting the head printer"?
