Slow 4 g
There is no slow 4g. It's either a throttle or weak signal from your carrier. Try it in a place where you are completely sure that 4g works flawless. This of course if your device is from Metro PCS as in heading and your wireless carrier is from them or at least T-Mobile. If for any reason you unlock the phone, if the device is GSM, and use it with a different wireless carrier, then it's another thing, and it could be the issue at hand.
I had the same issue. Its hardware related due to no good contact between the phone and your tiny speaker.
To fix it no too hard.
1) Open up your Samsung infuse case directions here video http://www.youtube.com/watch?v=ewdyo2fkJj8
or pictures http://androidforums.com/samsung-infuse-4g/532693-how-fix-samsung-infuse-4g-screen.html
2) The speaker is located bottom left corner (two etched holes for sound)
3) With cover off locate 2 brass/bronze tabs that connect the phone to the speaker.
4) Slightly lift these tabs make sure not to far to brake off (1 mm)
5) Put back the cover and phone speaker should work fine
I hope this helps.
