Tap on: main screen.
Tap on: Navigate to.
Tap on: Address.
Tap on:: Crossing or intersection.
Tap to select city.
Enter the street name.
Enter the crossing street name.
Tap done.
Depending on the operating system of your TomTom you should be able to tap the screen then tap the forward arrow until you see "add favorite". Tap "add favorite" then tap "address", then tap "street and house number". Type in the city. This will bring up a screen with several cities on it. Select the city you want, then type in the street name. the next screen will let you put the street number in. tap done. Tap OK on the next screen.
For posted speed limits, street names, etc, corrections can be made using the map corrections tab. For correcting a home address, I do not know. In fact, I have the same problem, i.e., an incorrect or unrecognized home address was enterred that I need to correct.
I have a tomtom too, and it sounds like the map files are corrupt, it should have come with a CD, you need to plug your tomtom into your computer with the given USB, and turn on TOMTOM HOME. You'll then need to go to "Back up and Restore" and restore your tomtom to the factory settings! Also you might try to push the very small reset button located in a little hole somewhere on the device, you'll have to hold it down with a pin or something! THAT MAY WORK... but i know for a FACT that the restore WILL.
ALSO, if you dont have TOMTOM HOME, you can download it HERE: http://www.tomtom.com/services/service.php?id=16&tab=87
Go to TomTom Home on your computer and do a update for your unit. In the update list you should see a GPS quick fix which helps the TomTom's aquire a signal faster. Hope this helps.
Yes, this is basically normal. This is not a
shortcoming of the GPS per se, but of the maps that it's using and
where on the map it has recorded that certain addresses are located.
The maps that the GPS systems don't (typically, to my knowledge) have
every building on them, instead they just have numbers recorded every
so often on the street and then the machine interpolates where a
particular address ought to be based on known intersections. E.g., 150
Foo Street ought to somewhere around the middle of the 100 block of Foo
St. on the "even" side of the street. So this is probably why it thinks
your apartment is slightly further up the street than it is; when
people build things, we often don't allocate exactly the same amount of
frontage to each street number, hence the offsets.
I'm still pretty impressed with my Garmin and doubt I could find my way home without it. Good luck!
On TomTom Go at least: Change preferences/change Home location/ Then select from several options. If you are at your home location then fastest is to select "my location", next easiest is to select "Address", then "Street and number"
I think that you just continued the wrong way. If you would follow the red line that is the way you should go. If you don't, then it will reset from where YOU went which was not the correct way to try to find you a new way to where you are going from where you have gone off on the wrong street. That has happened to me and it is only when I go the wrong way. I hope that helps..
