Brother SE350 Mechanical Sewing Machine Logo
A
Anonymous Posted on Mar 22, 2015
The safety feature was activated while I was sewing. Now the machine is frozen. Why won't it sew?
William Gilbert
Level 3:
Master:
  • Brother Master 470 Answers
  • Posted on Mar 23, 2015
William Gilbert
Brother Master
Level 3:
Master:
Answers
470
Questions
0
Helped
115665
Points
2377
My old Montgomery Ward sewing machine, m# 1957, acts like the needle mechanism is stuck, in the "bobbin refill" mode! The wheel won't budge. I have no book so don't know how to engage the needle arm!
As long as the bobbin winder is engaged, the machine will not sew. This is a safety feature.
Montgomery Ward Sewing Machine Instructions eHow
Check the large wheel on the right side of your machine. Is there a smaller wheel inside? On some machines, this is the mechanism that activates/deactivates the bobbin winder. Will that inner wheel turn? If so, check to see if that causes the machine to sew.
2answers
How can I get the needle moving?
the machine probably needs to be serviced, there could be an internal problem causing the machine not to sew
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Bernina frozen, nothing moves
it's possible that something has broken or come loose inside the machine and the machine needs to be checked..
The safety device continues to activate on my Brother PE 770
it sounds like the machine needs to be serviced to see that wrong
with the machine
2answers
Bernina 1130 power cord won't retract
since the machine is a bernina, the machine probably needs to
be checked at a sewing machine shop, to see why the power
cord won't retract
Brother 270D Jams when sewing anything
You might have thread caught in the take-up lever linkage and it has soaked up all the oil my recommendation would be take it to your local dealer
Brother 2001 sewing and embroidery machine.
The fact that your machine is turning hard says you still have some thread inside the machine that is binding up and activating the safety device. It must turn easily before it will work properly again.
Sometimes the machine must be disassembled to remove these threads.
sewman7
1helpful
Safety feature activated?
If you can return the machine and get your money back. this machine is nothing but TROUBLE and will continue to have problems.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
