Computers & Internet Logo
C
Craig Boyd Posted on Mar 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get a user manual for my Acer desk top aspire ax3400g,free?
Need info on audio connections on the rear panel. Type of jack and output. Compatibilities with Sony surround system, 7.1 capable
Ruben Caraballo
Level 2:
New Friend:
  • Expert 63 Answers
  • Posted on Mar 23, 2015
Ruben Caraballo
Expert
Level 2:
New Friend:
Answers
63
Questions
Helped
5980
Points
112
Lars Olsson
Level 3:
Brigadier General:
  • Acer Master 3,400 Answers
Lars Olsson
Acer Master
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1048473
Points
10330
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Sound
Your TV has both analog and digital sound output jacks. You will need to connect to an audio amplifier/speaker system that can use either of these types of audio signals. Consult your TV user manual for more info.
Got cox Digital cable box today, cox can not tell me how to hook up to box to make it rec/play. Info I read old cox papers from 2002 says I need a vcr controller, Cox does not know what that is and it...
For a standard VCR which is what most people have, all you need to do is connect a yellow RCA cable for video from the yellow output jack on the cable box rear panel to the VCR's yellow video input jack on its rear panel. Next connect a white RCA audio cable from the cable box white RCA output jack to the VCRs white RCA audio input jack. You can record a cable show by selecting the LINE input on the VCR and selecting the TV show on the cable box.
Now for playback, connect the VCR to your TV. Connect a yellow video cable from the VCR's yellow output jack to the TV's yellow video input jack. Same for the white audio connection. Select on the TV, the source input for the VCR. Its not complicated and you should not need any other devices for a standard setup with a digital cable box and vcr.
1helpful
How do I turn on the wireless in the notebook acer aspire 3000
Look on the front edge of the laptop, you will see what appears to be two clear looking buttons, the button to the left of the audio jacks is your wireless switch, the button to the left of that is your bluetooth switch. Below is the link to the user manual for that laptop, you will find this info on page 2 of the Acer Tour Chapter.
http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS3000-5000_UG_ENG.pdf
Connecting an Acer 6920G to a LCD TV
Unfortunately, DVI doesn't support audio. Your headphone output may work if you have a PC audio input on the TV. However, you might need to change the audio output on the Acer 6290G. It is probably defaulting to using the HDMI audio output.
Go to the Control Panel (click on Start). Select the Hardware and Sounds section. In Sounds, look for Manage Audio Devices. Change the Default Audio Device to a different Audio device (look for Output in the description). Note: you may need to turn off the computer and TV and turn them both on for the headphone jack cable to be identified.
If this doesn't work, check the manual for the TV. It might only have the PC audio connection available for a VGA port. Please add a comment with the TV model, if you need assistance with this step. Make sure that you aren't connecting the headphone out of the 6920G to a headphone out on the TV.
I hope this helps.
1helpful
2answers
I have an acer aspire 5100 laptop i need to hook up to my tv for a presentation tomorrow. there is no s-video output on it,. how do I hook it up to my tv?
If your TV has RCA jacks on the back or front. Input type. Then you can go to radio shack and get a vga cable to RCA jack converter. That is all you can do. Is the TV a flat screen if yes then you can hook up you pc with a monitor cable like your usine now in your house. Find out the type of TV.. Ask someone to check the tv for a computer port on the back.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Does Acer x1700 have internal speaker because I cannot get any sound. I have not been supplied with a handbook
..hmm, your user guide:
http://www.gadgetsmanual.com/acer-aspire-1700-series-users-guide.html
..tour of your specs from acrobatplanet.com :
http://www.acrobatplanet.com/manual-ebooks/acer-aspire-1700-series-user-s-guide.html
Check out above under "Multi-media", you have (4th bullet and 7th bullet) 'audio input and output jacks' + '2 stereo speakers & subwoofer'.
Might want to tell a good service center about that sound issue since
a NO SOUND problem might indicate not only 'bad stereo speakers' but
since you have a sub-woofer, that circuit might have blown (along with significant parts of your output audio).
WW
4answers
RCA Jacks
yes..those small ports, usually color coded for input output and microphone are in fact, RCA jacks..
your user guide will tell you which are which
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
