If printer spooler stopped when you try to print have you checked to see if anythings wrong with the printer. If so and nothing was wrong maybe your printer spooler is to full so it stopped working.
I open the run command you can type: net start spooler (You will get a message that says the print spooler service has started) If you still have issues open the run command and type: services.msc it will display a list, where you can find print spooler.
From there you can right-click on it and set it so it is started and runs automatically.
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select AutomaticService status click Start Then click OK MICROSOFT PRINT SPOOLER FIXES http://support.microsoft.com/kb/934885
Start and stop the print spooler Windows XP To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services. Under Console Root click Services (Local) In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo: Click Stop to stop the service. Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
Hi please turn off the printer and restart it after five minutes if you still have the problem please uninstall and reinstall the drivers for your printer.
if u not getting print due to " Spooler subsystem app has stopped working " Error then go to Run---->type "services.msc"------->u get services console----------->select "Print Spooler"go to propriety ---------->check start-up type ------>if it is disable select automatic &press start for get start (if it is alredy started then get service stop & after get start with automatic )
if there is problem in printing due to Spooler it should be resolved
if this information is useful for u please Rate me..........
hi! Print Spooler is actually a service for your Operating system- Try this
Click on start and click on run in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
