The play in the tub in normal, it sounds like you have an over sudsing issue, run an empty load with 3 cups of vinager in the tub, set the water temp to hot, cut way down on soap, if you use liquid dont even fill the cup 1/3 of the way, I know this sounds dumb but try it, I have one and this happened to me
I ran a load last night. Stopped it intermittantly to check inside. There was no sign of excess sudsing. There was no sign of water leakage until the final spin cycle - at which time a small amount of water droplets appeared from under the lid. Nearly all of the water leak (roughly 2 cups, slightly soapy) appeared from under the machine.
