Hello Martin;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on the upper inside wall of your fresh food section. So, I can not be accurate in regards to your unit.
1.) Inspect your handles. Are there 3/32" allen wrench screws at the top and bottom? If so back off the screws until the handle comes off. Then tighten the screw on the refrigerator door. Put handle back on the and tighten the 3/32" screws.
2.) No external screws - Then the handles are held on in a slip in slot fashion. Pull up on the door handle. This is going to take a little mussel. Remove the door handle. Tighten the screws on the door and the back of the handle. Slide handle back into place.
SOURCE: Loose refrigerator door handle
weavie, this is one of those ugly little problems. Get hold of a small screwdriver, a pointy knife blade or similar and stick it into the gap, however small, between the cap and the handle. You may be able to find a small indent or similar near the bottom side of the cap. Gently pry up. It will yield. Be patient.
SOURCE: Freezer Door handle came off after 1 yr.
I had this problem with the bottom freezer door of my Amana.
What I did was slide off the entire door handle by applying pressure pushing toward the right to get the handle off. Once the handle was off, I slid the clip (which was still clipped on to the door) off and screwed it back on to the handle. Once the clip was tightly secured to the back side of the handle, I carefully slid the handle bar back on to the door by sliding it to the left back on to the door clips until it clicked securely back into place.
SOURCE: Loose door handle GE two door freezer/frig model TFG 22JADAWW
Called and watched mechanic who clipped of top and bottom covers with a screw driver then tightened both screws and replaced covers. Cost was $100 but I could have wrecked the door. Needs a special little star shaped screw driver head with ratchet fitting. Now equipped for next time.
SOURCE: Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model. Mine was the fridge (not freezer) door handle ie. the upper door. There are no small holes on the bottom of my fridge handle. Working from the outer door edge, I gently prized loose the plastic trim located under the door. I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door. The trim will prevent you from using a conventional screw driver to tighten the screw. I used a screw driver bit which is only 25mm long. It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure. Good luck.
SOURCE: one handle is loose-how can I tighten it
shoulb be screws under cap on handle remove and tighten that should do the trick
