I used to have the game app Cookie Jam loaded. I can not load it on to the tablet. The app keeps shutting down.
SOURCE: setting up a laptop to use its tablet pc functions
XP Pro should run fine on it - I would assume that is what it came with. You may need to download additional drivers from Toshiba. I would check with Toshiba about the pen as well, but without it should still function as a regular laptop.
SOURCE: replace hard drive but can't load tablet operating system
I bouht one used and had no tablet pc restore discs, but my 40 GB hard drive was full of programs. I cloned the drive with operating system reimaged my 160 GB hard drive with the image. You need to use partition software to repartition the new drive to " see" the larger drive with free space. This can be done before or afte. I did it after because i had to go thru trial and error acouple of times due to no real concrete info on the web.
SOURCE: set up did not find any hard disk drivers installed on computer
Your notebook has SATA hdd. Got into the bios (keep pressing F2 key on startup) then in the bios screen find HDD and press enter. Select IDE mode. Press f10 to save changes and exit. When this is done install XP.
Alternatively connect external usb floppy drive and unzip sata drivers into that. When booting from xp cd press f6 to load drivers.Follow onscreen instructions to load drivers and continue xp installation.
Please let me know if issue not solved for futher ts steps.
thanx
SOURCE: keeps freezing after loading windows xp, won't allow me to use any apps or open anything
if you cant afford to get it repaired, then check the processor, hdd, ram slots to ensure that they are all in their fixed possitions,
the problem may be that a module of ram has come loose or your processor has, if they haven't then get yourself a digital multimeter and learn about computer electronics,, although buying a new computer maybe the quickest option.....
SOURCE: HOW DO YOU DOWN LOAD
Hi there:
Please refer to page 13 of this guide. It tells you how you can transfer files from your computer onto your Cruz Reader. You can transfer all your songs this way:
http://s3.velocitymicro.com/vmcruz/R101/manual/ReaderGuide12-30-10.pdf
If you need additional help feel free to leave a comment here.
