Have checked connections, unplugged the unit and flipped on but same result.
SOURCE: TV won't turn on and red light flashes 6 times.
my sony 40 inch lcd tv flashes 4 times and wont turn on? Any ideas?
SOURCE: tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
SOURCE: Tv will not turn on
all you have to do is replace the 25 volt 1000 uf capacitor on the inverter board. there are 2 of them. typically, only 1 goes bad. I had the same problem, replaced the ca, and now it works great.
SOURCE: Hisense TL2020 - Won't come on.
Lay unit flat on table, remove stand and rear cover. When you remove back, you will see a power supply board in the middle of the set.There are (3)1000mfd @25 volt electroltics and (1)220mfd @16 volt electrltyic that have to be replaced to return to normal operation. This is not something to try if you are a novice as you must observe polarity when installing these caps. But this repair WILL return set to normal operation.
SOURCE: my Sylvania TV LC320Sl1 will
lori2scott...did you ever solve your problem? Mine is now doing he same thing and I dont know what to do. Thx pwest17
