SOURCE: What is the problem if
Pressure Switch faulty.
Replace with P/N: 6501EN1001A
Reply if you need directions for removal & installation.
Good Luck!
* If you found this solution helpfull, please rate with 4 thumbs up & a testimonial.
Call LG's support line, they have excellent customer service.
SOURCE: Hi ihave a lg fuzzy logic wf-1022tp top loader.
You have a problem with the pressure switch (water level sensor).
Either a faulty switch, blocked air chamber or hole in the pressure hose linking the chamber to the switch.
Thanks
