After I tried to stop my washer and open the door, (by pressing cancel a few times) I now get and error message ( 'err' ) blinking no matter wich button I press.
If you are still receiving an error code PAU after resetting your washer, then the door of your washer is probably not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If the issue persists, then your washer could possibly have a faulty door latch, door strike or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. Best - Z
Hi The light is
flashing due to the door lock error. The door lock is activated as the machine
experienced an error or was stopped in middle of a cycle. Or the door was being
pulled while the machine was running a cycle. Try unplugging your washer and
restart the washer to check if you are still getting the same blinking light.
If error is still not resolved then start the rinse/spin cycle & stop
the cycle, now press and hold the cancel button for 5-10 seconds. However,
if you are still not able to get the door open then you'll need to open the
door manually by disassembling the washer. Hope this helps... Please post back
for any further assistance. Daniel
Try the following two buttons: press Options and Select together for 10 seconds (or until the LOC disappears). The pair of buttons held for 10 seconds also sets this control lock.
To find out the error code, turn the Program knob to the start position, Spin Only. Press Start/Pause to start the cycle. Press Cancel to stop the cycle and turn off the LEDs. Press Cancel again and within 5 seconds press and hold the Options and Start/Pause buttons until the LEDs start chasing. Then release the buttons. Turn the Program knob seven clicks clockwise from the Start position. The control will signal the last error code. To clear the error, press and hold Options and Start/Pause for 3 seconds. Then either unplug the washer for 5-8 seconds before plugging it back in. Alternatively, press and hold Options and Start/Pause together for a few seconds until the Wash LEDs appear.
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
This error code indicates that the door is not locking. Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it. Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed. To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
Unplug the washer or disconnect the power for one minute.
Plug in the washer or reconnect the power.
Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
ERR=An error has been detected PAU=Cycle has been intrupted 58=High current on motor phase
To clear latest stored error code: • Turn the Program Knob to the start position, Spin Only. • Press Start/Pause to start the cycle and save it. • Press Cancel to stop the cycle and turn off the LEDs. • Press Cancel again to turn on the LEDs. • Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons. • Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code. • Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared. • Exit Diagnostic Mode to return the washer to normal operation. a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons together for a few seconds until wash cycle LEDs appear.
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
The F26 error code on the Duet washer is a door switch error. The button inside the door opening might be stuck so that it doesn't register as being opened and closed. First press the pause/cancel button to clear the error display. Next push the button inside the door opening a few times and pull it so that it pops out completely. That should solve the problem.
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things first...Catriver..post back.
