The printer was turning on fine, and it show all displays, but yesterday went i turn it on , it only show a blank screen and after a few second it starts exiting paper and noting more. I cannot enter the ip.
SOURCE: Zebra Z4MPlus doesnt communicate with PC
Ok,
This machine has a parallel port. Try to print via parallel cable. If it works, consider staying with it. Serial ports are a pain to manage.
If you absolutely have to do it via rs232 though....
Question 1. Has it ever printed?
If yes, Go into Windows Printers and Faxes control and select the Zebra or whatever printer that you are using. Right click on it and you should get a menu that at the bottom say "Properties", select that, then you should get a new window with tabs at the top. You want the tab for "Ports". Select it and you will see all of the different output ports that you can direct your printing. RS232 is a COM port. So start at COM1, check it and try to print. If that doesn't work, go to COM2, etc.
Last resort, If you can't get control via the printer driver program, you
will have to try redirecting the print manually (now you will
understand why I said to stay with parallel output).
What you have to do is redirect your printing via the dos "mode" command.
Under "Start Menu" goto "Run" and put in "CMD" and click "OK".
This opens a black square window with a cursor blinking. Type in this:
mode com1:9600,n,8,1 (enter)
mode lpt2=com1 (enter)
Tell your program to use LPT2 if you can and see if it works.
By now a parallel cable instead of RS232 should be looking really good.
SOURCE: Zebra 4M printer stopping due to error message
The printer is dirty sensor label or no label is calibrated. Turn off the printer and press FEED, CANCEL, PAUSE and turn on, release the keys to advancing the label, and let print be calibrated. Roberto Martinez Mexico [email protected]
SOURCE: zebra z4mplus
It happens that the printer is not calibrated to the labels you want to print. A quick fix is to restart the printer with its factory settings, press FEED and PAUSE when you turn the printer, release the keys when label feeding.
Roberto Martinez
SOURCE: Zebra Z4MPlus not printing dark enough
Problem is the temperature, printhead not hot enough. Download the zebra setup utility, you can use this utility to configure the print quality.
Heat setting can be found in the printer driver and easily adjusted there.
SOURCE: My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
