We recently had the same problem. Took it to the "Apple Geniuses" and they used a soft brush to clean lint out of the hole that the charger plugs into. Problem solved. They said don't blow in the hole, and use something gentle so as to not damage the contacts.
It will charge, but it definitely takes a whole lot longer.
just like the iPhone charging block, will not charge the iPad.
You need the supplied charger wall block for an iPad.
Usb at computer have too weak current to charge ipad, you need wall charger.
SOURCE: Can't charge the ipad from the USB charger
To get Ipad to show as charging download Asus AiCharger from web and
restart computer after install.Plug in usb from Ipad and should now show
charging
http://event.asus.com/mb/2010/ai_charger/
Please Rate
