After color printing paper back is not clean
SOURCE: Printer will not print ,paper comes out blank
Put new in cartridges in printer.
Page prints out blank.
Have cleaned the print heads 3 times.
Need help!
SOURCE: Producing blank pages
repeated nozzle cleaning (6 times) which almost emptied the cartridges but it is now printing
SOURCE: Please help me, my epson inkjet all in one printing just blank blank blank
I have the refillable cartridges and they work great. They come with the "chip" that resets every time you turn it off.
SOURCE: Still getting blank pages.
You have air or dry ink in the nozzle chambers, you use the head cleaning facility but when it finishes it asks you to print a nozzle check pattern, click the finish button.
You need to do 4 head cleans and cancel the nozzle check print after each until the 4 are done then allow it to print the pattern.
This will prime your heads and clear out any air locks.
The only other thing I need to check, but it's a bit of a numpty suggestion. If you have not removed the yellow 'tear off' strips, no ink will flow and your chambers will be full of air. If this is what happened, remove the 'tear off' strips and carry out the procedure above.
I hope this helps.
You don't need the utility for this but it would be handy for you to have.
It is quite easy to find, it's on our home page and on the Epson page just below the big blue drop down menu box. It's simply a 'click here' link along side the text "If your printer needs resetting" etc etc.
Nige
The INK Store
SOURCE: epson cx3810 printing blank copies
I had the same problem and had to clean the nozzle tubes. After cleaning the tubes, printer worked great again.
Hope this helps.
Charlene
