Turn knob to 12 o'clock position
turn to 6 o'clock position
press an hold the spin button
turn knob to 7 o'clock while still pressing the spin button
let go of the spin button after 5 seconds
turn the knob back to 12 o'clock
assuming you have repaired you're f21 motor issue it should behave its self
SOURCE: i have a bosch maxx
From the user manual in English:
F:21 - Motor fault. Call customer service!
SOURCE: How to reset the error codes (F21) on Bosch Maxx
See this url
http://experts-univers.com/mon-lave-linge-bosch-maxx-7-ne-fonctionne-plus.html
SOURCE: Error code F18 for Bosch Maxx 7 Silence washing
F-18 means the pump is blocked.
First checkthe filter for coins or other junks. Make sure the drain hose isn't blocked, restricted or kinked. Make sure there's no obstruction in the drain standpipe or U-bend.
If this doesn't work, might as well change the drain pump assembly. http://www.espares.co.uk/parts?k=pump
Hope it helps. ;)
Thanks for using Fixya. A 4-thumbs up for answering your question is greatly appreciated.
SOURCE: How to reset the code
Hi F21 error in your Bosch washer relates to a motor or a
control board fault. This can be reset and to reset it turn the appliance knob
to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and
then press and hold the spin button, then while holding that button turn the
knob to 7 o'clock position, continue holding spin button for 15 seconds and
then turn the knob to off. After a minute turn it back on, if the error code is
still there then it means that the motor or brushes in the motor should be
replaced, though it is always better to replace the motor assembly completely. Hope
this helps...please post back for further assistance. Daniel
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
