Hoover Dynamic 8 DYN8144D White 600 mm Washer Front Loading, 8kg, A Energy Rating Logo
j
john english Posted on Mar 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code e08 mc fills buzz as actuator starts but motor failsa to cut in will continue to fill and drain within cycle bur never turn motor
Jorgie the appliance guy
Level 3:
Top Expert:
  • Hoover Master 5,639 Answers
  • Posted on May 14, 2015
Hoover Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1522456
Points
32630
First use a multi meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Another test u can make with a multi meter is by testing the prongs individually.
# 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch.
(where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
If both check ok then next CHECK the motor coupler (a bad couplercan be checked by looking under the machine and taking note if there is a black residue on floor, look at coupler located between the motor and tranny, and see if it is broken up or missing any parts? Try to turn shaft by hand and notice if it does not engage tub? )
or belt if belt driven. Check for loose, broken or worn belt .
Then check the door switch with a multi meter for continuity OHMS when door closed and infinity when door is opened , and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Also check THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well. for worn broken teeth
By the way my advice is free cuz God is good!
error code e08  mc fills  buzz as actuator starts  - error-code-e08-mc-fills-buzz-as-actuator-qwraf2tofhw5f1pyjgshzkpc-3-0.jpg
4 Related Answers
A
Anonymous
  • Posted on Jul 16, 2007
SOURCE: WASHING MACHINE FILLS WITH WATER AT START THEN STOPS SHOWING ERROR 5
the carbon brush may be worn out and need replacement(these are a pair of componet that makes contact to the motor. Francis
Anonymous
  • 41 Answers
  • Posted on Jul 14, 2008
SOURCE: Over filling of water and fail to wash cycle
blocked pressure switch hose
Anonymous
  • Posted on Oct 01, 2011
SOURCE: the washing macine, continues to
Your discharge hose is forming a syphon You need to arange a solution to break the syphon effect without causing an external leak such as a "T" piece at the top of the discharge hose with a valve. Shuts off under pressure (when pump is opperating) but opens when under suction (trying to syphon)
dtcparkdene
dave cousins
  • 3 Answers
  • Posted on Sep 18, 2013
SOURCE: Hoover WMH168D error code E08
I posted this elsewhere by mistake, I have a Hoover Optima which had an E08 fault, the forums suggested a Tachometer issue. I fixed the fault it was just the motor brushes. i made a video including testing the tacho and changing the brushes that cost me a tenner. easy fix hi I had this fault google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on you tube http://www.youtube.com/watch?v=xYn-f78GB4U if its any use.
My hoover dynamic 8+ washing machine Model number DYN8144D-80D displays an E08 error Code
E08 is the motor speed sensor error code. Suggestion: Try a cycle with very few garments and see if it completes the cycle.
Not finishing cycle
Is it draining out the water?? Dishwashers fill, spray, and drain more than several times during a cycle. After starting a cycle, let the unit fill, start spraying, and then cancel the cycle--listen for the drain pump activating and pumping out the water. If water is not being drained properly(within a certain time limit), the unit will error code out and stop. Also, make sure the filter is clear--if it gets clogged with "muck", enough water won't be sprayed onto the dishes properly, the pump will require too much energy to try to pump water, the control will sense this and shut down the unit to protect it.
Washer will fill and drain but will not wash or spin
you have a motor problem. do you hear the motor working? if so it may just be the belt.
Fills up with water, wont wash, drum motors works
Sounds as if this computer is trying to display an error code. If switching cycles manually makes it work, then it is most likely a bad circuit board. Try doing a google search for "Kenmore washer lights blinking" or something to that effect.
LDF7932ST leaks while filling
Has anyone checked the drain hoses inside the machine. My LDF7932 dishwasher was doing the same thing and it turned out to be one of the drain hoses had a crack that was leaking causing a short in the wash motor and a leak in the machine--hope this helps.
Good luck
Nancy
The start delay flashes in the middle of a cycle on a hoover washer dryer nextra 6 . it drains but doesn't spin
Program error due to maybe a delay in the fill and drain cycle, Get the inlet and outlet valves cleaned( drain should be quick)
Now if during the cycle the program is cutting off voltage to the motor, then the control board can be faulty.
Check if the drive is having connection fault to stop the motor voltage.
2answers
I have a whirlpool duet washer that will not spin at high speed and shows error code f 06
Error F06 is Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes. Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
