Mobility battery manufactures say that their batteries can need to be charged fully then drive chair to discharge them about 10 percent then repeat this 15 - 20 times. This process brings the batteries up to full capacity. Do not drain new batteries completely till after the charge and drain process has been done. It is also possible that the new batteries are not good as suggested.
Hope this helps.
Hello,I would get back to where you purchased the batteries and go from there.Take the charger also to ask them to test it,also keep the old batteries as they are as you say.Still okay.Take care and I hope this helped you.Colin
SOURCE: only 1 battery charges
The lights are working, the batteries aren't. Red indicates power to the charger, and it should be on all the time. Green indicates a full charge, usually. If one or both of the batteries are totally dead, then the charger can't "see" them, and you will get a green light, but you will have dead batteries.
All power chairs use sealed, deep-cycle batteries. Deep cycle batteries, are designed for slow amperage dischare over a long time period, unlike a car battery that throws out a lot of amperage for turning the motor over. That's called "cold-cranking amps", and you can load-test a car battery to see if it will throw out a ton of amps for long enough to start a car. There is NO load tester made, or possible for a deep-cycle battery. A load test requires a 24-hour time period, and a complicated formula.
So, your course is to get some fresh, gel-sealed-batteries. You will need type U-1. Specify, gel-sealed-batteries when you go to the battery shop. A fresh set should get the chair up to about 12-16 mile range, which would be about 3-4 hours running constantly at high speed. Good luck.
SOURCE: the orange idicator light is flashing.
Replace the batters and used the correct battery charger, Not a car charger.
SOURCE: my pronto power chair m71 standard the battery
anne no It means you need new batteries. If Medicare paid for your chair then they will pay for 80% of the repair costs. Contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-80467-2668 and they will send a tech out to check it for you and bill Medicare Hope this helps
Morning,its people like yourself that i am here.Please visit:www.alldatasheet.com
