No heat and fan working usually means the heating element has failed. Before you go down that road get the oven light checked as well in case there is a central problem. If by no oven light you mean the internal oven light is not on then that is just a bulb replacement. Make sure you get a heat resistant or original spec one though.
If the main oven fan is working but no heat it is most probably the ring element which is around the fan blade inside the oven.Check it is the element before you go and replace because there could also be an issue with the thermostat.Hope this helps.
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
If the fan is working, but there is no heat in the oven at all, then it is going to be the element that is faulty, assuming it is an electric oven.
If the fan is rattling, then could be loose fan blade, or the bearings are failing.
Hope this helps.
Oven functions Oven light. Upper and lower heating elements. (Conventional cooking). Upper and lower heating elements with fan. (Fan assisted cooking). Lower heating element with fan. Inner grill heating element. (Radiant grill). Full grill heating element with fan. (Fan grill) Rear circular heating element with fan. (Fan forced cooking). http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
hi,
If the fan in the back of the oven is going round and the temperature light is on, but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available on Ebay.
To gain access to the element you will have to remove the backplate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. If your fan oven is getting warm but takes a very long time to cook anything, then you need to check if your oven fan is working. As the element is heating but the fan is not blowing the heat into the oven. To replace the oven fan motor is a little more expensive and a bit more involved.
The heating element is the likely culprit as they burn out and go open circuit..(ie ...disconnected and will not heat up ) If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Neff fan oven element video.1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter. To gain access to the NEFFelement .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the elementis open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine. 2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motoris working you will see the blade turning fast if it is ok. if the element is heating but the fan motoris not blowing the heat into the oven then you need To replace the oven fan motoris a little more expensive and a bit more involved. 3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat 4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timerinto AUTO mode, simply put oven back to MANUAL mode and all should be working again. For all Free appliance repair videos visit our VIDEO TUTORIALS
we just had the same problem with the same oven. pull the oven out of the wall. on the top right side there is a fan. there is a safety switch that is activated by the fan blowing on it. a piece of insulation was preventing the switch from activating so the oven thought the fan was not running. remove the insulation and the oven comes back to life.
