Microsoft Outlook Express Logo
Herman Michiels Posted on Mar 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do dbf viewer do?
How to treat mistakes .dbf - tethers base 1C 7.7. When booting after the election by an error error -200 1SCONST.dbf and knocks 1C. When testirovatii provides more pieces of 20 errors dbf files. Can I do something? Prompt recovery program headers dbf-file?
hayatibinesah
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 25, 2015
hayatibinesah
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
209
Points
A linked server is basically just a pointer that lets the code within your database interact with external data sources as if they were also within your database/instance. There are some examples here for creating linked servers to DBF Viewer Tool:
http://www.dbf.viewertool.com/
So for example if you had a linked server to a FoxPro database called MyFoxProDB you could run a query within SQL Server like this:
UPDATE t
SET t.foo = x.bar
FROM dbo.LocalTable AS t
INNER JOIN MyFoxProDB...TableName AS x
ON t.key = x.key;
You could also consider using OPENROWSET as described in this question:
http://www.filerepairforum.com/forum/databases/databases-aa/dbase-iv-clipper-foxpro/964-how-to-restore-a-corrupted-file
pranay solanki
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Apr 03, 2015
pranay solanki
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
3594
Points
45
There is a simple tool which can recover the corrupted dbx file.just follow the link-
https://code.google.com/p/undbx/
Level 3:
  • Microsoft Master 7,733 Answers
  • Posted on Mar 29, 2015
Microsoft Master
Level 3:
Answers
7733
Questions
0
Helped
1863751
Points
21487
1helpful
2answers
What does 'Unknown Server Error 500' mean?
This is caused by incorrect MIME handling by Windows when 'DBF Viewer 2000' is installed. The 'DBF Viewer 2000' program associates the .DBF file extension with 'application/DBF Viewer 2000' instead of 'application/octet-stream'. Remove 'DBF Viewer 2000' from the affected system. If you are still experiencing the issue I can suggest this program DBF Repair Toolbox https://www.repairtoolbox.com/dbfrepair.html
Recovering .dbf files without .dmp files
Sub ABC()
Dim r1 as Range, r as Range, bk as Workbook
set r1 = Activesheet.range("A1?)
set bk = workbooks.open("C:\Myfolder\Myfile.dbf")
set r = bk.worksheets(1).Range("A1?).currentRegion
r.copy r1
bk.close SaveChanges:=False
end sub
That is the way I have been doing it successfully in xl2003 and earlier for years. Support for Saving as DBF was dropped in xl2007 for sure but I believe it can still read a dbf file.
http://itknowledgeexchange.techtarget.com/itanswers/how-do-i-open-a-dbf-file-to-a-tab-in-my-worksheet/
1helpful
How to recover a database on known *.bak file?
Completely - in any way. If you find also tbk the file - then is possible. bak is
backup copy of the dbf file, tbk - a backup copy of fpt (there a memo of a field are).
However you were perhaps lucky, and actually fpt the file wasn't cleared.
And it is possible "to restore" of course simple renaming of bak file into dbf file. Of course then have to be reindexed the table, and if the structure changed, in general, to recreate the indexes from scratch. and perhaps "to treat"
the container Database dbc/dct (if you use it of course).
If so it doesn't turn out, then try to restore through DBF Viewer Tool. It well restores.
Come here on a forum and look at councils for this subject is there.
http://www.filerepairforum.com/forum/databases/databases-aa/dbase-iv-clipper-foxpro/1355-help-to-repair-dbf-file
1helpful
2answers
Error 0x00000709
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
you might be able work your way through the problem.
Method 1:You may try the steps from the link and check.
Printer problems in Windows
http://windows.microsoft.com/en-US/windows/help/printer-problems-in-windows
Method 2:You may try to uninstall and reinstall the printer and check.
Reinstall printer in a clean boot state with the latest drivers from the manufacturer website.
Uninstall the Printer driver from the device manager.
a. Right-click the My Computer icon
b. Select Manage from the menu.
c. Select Device Manager from the System Tools that are listed in the resulting display.
d. Right click on the Device.
e. Click on the driver tab.
f. Click on uninstall.
g. Restart the computer
Download the latest printer driver from the manufacturer website and check.
http://windows.microsoft.com/en-us/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
Refer the steps from the link to perform clean boot.
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
Note: After trouble shooting put the computer to start as usual by performing step 7 from the above Knowledge Base article.
Install a printer
http://windows.microsoft.com/en-us/windows7/install-a-printer
Find and install printer drivers in Windows 7
http://windows.microsoft.com/en-us/windows7/Find-and-install-printer-drivers
I need the DBF Viewer 2000 Registration Code to open the viewer. I've been searching all over the internet but nothing was there.
Unfortunately I can't help you to find out reg code. But for view .dbf see below http://www.dbf.fixtoolbox.com program can open, view and even recover .dbf. It quickly finds out the proper file and quickly finished the process.
4answers
HOW TO SOLVE VFP FILE CURRUPT WHEN POWER FAILURE
At times, you may view that your MS Visual FoxPro 9.0 database is behaving abnormally. Some of the abnormal symptoms could be an error message while opening any database table, invalid characters in place of pre-defined values, and and more. The main reason for abnormal behavior of the database is its corruption due some logical crash. Few common reasons for corruption of MS Visual FoxPro 9.0 database are abnormal termination, faulty network devices, simultaneous modifications, conflicting third-party software, and incompatible service packs.
To overcome such database corruption scenarios, the user can use an up-to-date backup and perform restoration. However, restoration fails in cases where the user either forgets to create a database or the database backup itself gets damaged. In such cases, the database users can use a third-party DBF File Repair application to repair his/her corrupted database.
To illustrate the above case, consider a real-time scenario wherein you execute a query to modify your MS Visual FoxPro 9.0 database. While the query was performing the modification, the system shutdown due to power failure. However, the next time you tried to mount the database, you encountered an error message that did not allow you to access the database records. Moreover, the same error message appears every time you try to access the database.
Cause:
The root cause for the error message is MS Visual FoxPro 9.0 database corruption due to improper system shutdown.
Resolution:
The database corruption error message can be surmounted by following the below steps:
Use a complete database backup and perform restoration. However, in case of database backup unavailability, you will need to search for a commercial DBF File Repair utility.
A third-party DBF Repair application uses effective repair techniques to repair logically damaged MS Visual FoxPro 9.0 database and restore it at a new and safe location. The original database during the repair process remains intact. The tool is easy-to-understand and allows even a non-technical person to perform repair.
DBF Recovery Software is a comprehensive solution to repair databases created in MS Visual FoxPro 9.0, MS Visual FoxPro 8.0, and MS Visual FoxPro 7.0. The tool also repairs databases built in dBase III, dBase IV, and dBase V. Supported by Windows 7, Vista, 2003, XP, and 2000, the DBF Repair tool creates a new repaired file that can be attached to existing database.
Tanvi Sharma is a self employed Internet entrepreneur and product reviewer. This DBF Repair utility is extremely useful when the dBase and Foxpro database gets corrupted due to internal program errors, hardware malfunctioning, accidental deletion of data and more. This DBF Repair software repairs all types of database components including table name, column name, column data type, indexes and primary keys.
1helpful
Import .dbf file format to tally 7.2 file format
Exist some tools for solving like issues, and to my mind one of them might be able to help in like situation. I found out one of them on an one soft forum - dbf recovery.
Rear projection mitsubishi vs5042 no high voltage
Are you talking about the LV power supply or the HV power supply? The terminology your using is related to the horiz drive circuit. Have you checked the B+ off the regulator which should be about 120v or, it will on the pc bd for the correct voltage. Do you have sound? If you do then you will have to use use your scope to see if you have proper drive at the base of the Horizontal Output Transistor. Then we can go from there. Oh, by the way I can tell by the voltage readings you stated both of those transistors of turned off.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
