Do you mean Cortana, the Microsoft nosy application that records what sounds it hears and where you go and what you search for on Bing or Google or Yahoo and invades your privacy in despicable ways?
Under the Photos section, make sure My Photo Stream is turned On.
You can also enable Photo Sharing at the bottom so you can create photo streams to share with others and so they can share them with you
now every time you take a picture or save a picture and are connected to WIFI the photo is automaticly saved in your photo Stream.
if you are looking to share you photo stream with another IOS person you would use the share card and click icloud enter the pesons apple id and click share.
it may be like a phone once you have set up an account to sign into it automatically stores that 1, so u would need to set up another log in account manually & then when u attempt to log in it will ask which 1 u want, if you cant set up more than 1 account, then u have to manually delete yours & then use his.
Sign into your FB account then go to settings ( this is the symbol that looks like a pad lock with 3 lines next to it) once there look to the left side of screen at the top you will see where is says general account settings, click that and you will see about the 6th line down on that page it will say language. go to the right side of that line click on edit and there you go. Hope this was helps. Have a great day. :)
The FB app is tied to the account used to login; to share the tablet, but not your accounts via the app, you may always need to log-out of the account. Alternatively, you may search for 3rd party FB apps that handle more than one account. Hootlet and Friendcaster are two of several 3rd party apps that can manage/handle multiple FB accounts.
If you changed your password in the FB app, you will also need to change the native iOS/Auth module in setting on the iPad. Once you do this, you should sync up. See the image to see where to do this
