Re: what would cause my 26 inch avalon bicyle to make a...
Are you going 1 gear at a time or trying to go from first to high. On some bikes you have to allow the chain go from one gear to the nest and up the line or it will make a noise.
May want to look at the front axles. If the boots are torn and the joints are dry, the axle is causing the clunking noise. Also,check the transfer case fluid level,low fluid level can cause the noise due to dry or damaged gears.
2001 Saturn SL1. Transmission (automatic) shifts hard when putting it in gear and every gear there after. The only codes I get is PO442 and PO410. Any help would be greatly appreciated.
Your issue is a bad "speed sensor". Your speedometer is controlled by a sensor in your transmission, and when it quits working your speedometer will not work, it can cause very irregular shift patterns and slipping. Replacing your speed sensor should resolve your issues.
I hope this helps you, and I wish you luck on your repair.
Sounds like youi may have a few serious problems going on to have that kind of back lash occuring at higher speeds. I have experiance with low spped clunks on Bronkos and your type of vech being a car dealer. One you might try for low speed clunk on take off and braking at stop likts just completeing a stop? Pull the drive shaft and lubricate the splin - two check your leaf springs for weakness and wore bushings - take a look at your shocks - three u bolts holding springs to rear axle housing may be letting the axle housing actually dip or tweak or all those thing in combination - now you may have some serious slop in the pig - transfer case may be causing that clunk - as far as high spped clunk and activity you have a serous problem and you just might drop the transferr case have an accident fliping over..............Mike South Bend Indiana don't just keep driving and making problem worst...........
