This sentence is on a display all the time. I can`t do anything, I tried everything, like: opening, cleaning, air blowing, turning on & off. But the error is still there.
Open the top and back covers. If you see any jammed paper or other item, gently pull it out, then close the covers. If the error message remains, open and close the covers again. If the FAX/MFC cannot reset itself and return to the date and time prompt, it will display MACHINE ERROR XX. Please call Brother Customer Service and tell them the Machine Error number at: In USA: 1-800-284-4329 In Canada: 1-800-853-6660 In Montreal: 1-514-685-6464
This error comes when media doesn't come to fuser delivery sencor with in the specified time it may be due to improper paper picking or fault in registration ***...
clean the paper feed rooler & registration *** path ur problem will resolve defin...........
Mine had a similar problem. I assumed there might be some dust on the laser. I used an air compressor and pointed it at the DVD slot as it was opening and closing to blow some air around inside the unit (and hopefully dislodge any dust). It worked. The discs that would not play before did play after. I didn't have the air compressor nozzle too close to the opening as I didn't want to dislodge anything I wasn't supposed to. If it was dust on the laser, you might be able to clean it in other ways, such as removing the cover and using a cotton tip (take power off first!). That would have been my approach if I didn't have an air compressor.
hi.... I have this same problem every time.....first unplug it.....I use a clean cloth that is soaked in Rubbing Alcohol (not nail polish
remover, but pure rubbing alcohol). I basically open up the back, and
clean each roller. There are two green tabs at the top of the back of
the scanner. These need to be opened up (be careful, because the parts
sort of fall out if you're not careful, and they are difficult to
re-assemble).
Again, wipe everything down with the rubbing alcohol. Close up the
upper tabs. Make sure you wipe down the glass slits on both the door
(front-of-the-page scanning port) and on the unit itsel
(back-of-the-page scanning port). Before you close up the back door,
let it sit for about 5 minutes, allowing the rubbing alcohol to
evaporate.
The 1203 error message is caused by a communication failure between
one of the printheads (cartridges) and the All-In One (AIO) or by a
short in one if the printheads. The procedures in this article will
help you to resolve this issue. Troubleshooting a Communication Error between the Cartridge and the Printer
StepAction1Power
off the AIO and remove the power supply from the back of the unit. Wait
30 seconds, then reinsert the power supply, and power the AIO on. Did the error message return? Yes: Continue to step 2. No: Print a test page. If the test page prints, the error is resolved. 2Power
off the AIO and remove the power supply from the back of the unit. Open
the top cover of the AIO. Using the carrier belt, gently move the
cartridge carrier to the middle of the unit. 3Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return? Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark. No: Continue to Step 4. 4Power
cartridge carrier to the middle of the unit. 5Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return? Yes: Continue to Cleaning the Cartridge Contacts, and then repeat steps 4 and 5 of this procedure. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6. 6Power
cartridge carrier to the middle of the unit. 7Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return? Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Print a test page. If the test page prints, the error is resolved. Cleaning the Cartridge Contacts NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1Power
cartridge carrier to the middle of the unit. 2Remove the cartridges. Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts (click here for instructions).
try to open the top flip there are four screw covers around your display then take them out whit a little pin then take the screws out whit the t5 screw driver after that hold the caller id down whit your left hand and pull up the top flip whit ur rigth hand or u can use a thiny plastic around the top flip to take it out after u take it out u will see two flex cables on the top one is the end of the camera and the other is the end of the flex cable. pull the flex cable up and desconect it clean the flex cable connector whit alcohol or just blow it then put it back a little hard till u heard the click then try to clean the camera connector there is a little brown plastic on the top of the camera connector pull it up and open it like a door after u clean it put it back and close it then put the side keys back if they were moved then the top flip, screws, and screw covers.
if the problem still u have to buy the lcd display but the lcd is too expensive it would be better to buy another v3
OMG! I had the same issue and blew on the lens. To easy to be true, but it worked! I thought maybe it was a fluke, so I turned the camcorder on and off several times, and it worked every time! Sure beats the $341 Sony was going to charge to fix it!!!!
