NO! you need to remove the bearing retaining nut first. That's the big silver disk with a 10mm hex recess. It's very tight!NO! you need to remove the bearing retaining nut first. That's the big silver disk with a 10mm hex recess. It's very tight!
You can't post conmments that contain an email address.
Striker pin problem / broken connecting rod OR 1 o-ring 1 610 210 195 pos 165 thats become soft and not round anymore that will lock the striker in the sleeve when the lubrication gets older
The most caused suggestions but a cylindrical gear thats broken is rare
Bosch hammers work better under all environmental conditions with bosch grease part# 1615430010 or equivalent (such as hitachi, skill, or makita hammer grease). Bosch grease is light, slightly sticky with a high dropping point. If the grease is heavy and really stickey the hammering action will not be as desired and may get vacuum lock and not hit at all. Be sure to store hammer with nose pointing down to prevent hammer/anvel from slipping too far back into cylinder. In the case of Bosch hammers, more is not better. Too much grease has a negetive effect so just light application will go a long way. Good holidays
go to www.boschtoolsservice.com and request the information on diagram and/or instructions for replacing brushes. Also, instructions should be included with parts.
you can go to Boschtools.com and download a parts breakdown for this tool with the explosion showing the assembly. Let me know if you need more assistance.
