Unit should not continue to heat water after hot water tap turned off. After several seconds it gets too hot and pops the thermal switch. Any remedies or thoughts on why this is happening would be appreciated.
SOURCE: tempra 12 the when you
I am a free answerer, and I specialize in giving you resources for free.
The paid answerers may have a person who knows your product and the problems associated with your model.
I only see the questions where people have not paid.
Each day I see 20-25 unanswered questions about tankless water heaters.
And the day before, the same number of unanswered questions about tankless products.
The number of questions shows the complexity of the machines, and the inability of the manufactures to take care of their customers.
The manufacturer will refer you to the installer.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
There are not many ways a do-it-yourselfer can fix a tankless.
In contrast with tankless, tank-type water heaters have generic
troubleshoot steps that lead to a quick diagnosis, and same-day repair
of almost any brand. Most times a tank-type heater repair can be DIY.
SOURCE: The unit is no longer heating the water. The red
This will be a thermostat or element problem. The red light tells us that you have power to the unit. If you are handy you can test the thermostat and the element with a continuity tester. A voltmeter may also be used. This will tell you where the fault lies.
SOURCE: stiebel eltron 12 the thermal breaker keeps
Hello; I can't clain any formal training or education in electrical, But, I am a home owner and Mechanic so I'll give this a try. Thermal switches are in the norm based on the bi- metal concept/ Automotive flashers are in essence thermal switches. Of course there are electronic types that contain points and a coil, we can forget those since we aren't doing a car or truck, let alone turn signal. OK, moving on. As you know,excessive continuous heat generated by a excess load will destroy the bi-metal strip which serves as a bridge in the circuit. A defective flasher will increase in speed as it gets older and used heavily. Anyway, to the point. I've experience thermal switches that cease to function if trip too often or were tripped by an excessive load. Although resettable initially, it's thermal tolerance gets shorter and shorter until eventually you get irritated enough to ask someone on Fix-ya for some input. No problem. I reccommend replacing the breaker with or of same amperes. You may want to verify the load by checking the appliance data plate just in case it's the straw the breaks the circuit I hope I helped you and I apologize for the analogy used. Thanks for using fix-ya. Good Luck _Ned_t
