We used our scanner at a different location now the host connection is wrong. I need to find out how to change host id
Wireless Local Area Networks (WLANs) allow mobile computers to communicate wirelessly and send captured data to a host device in real time. Before using the mobile computer on a WLAN, the facility must be set up with the required hardware to run the wireless LAN and the mobile computer must be configured. Refer to the documentation provided with the access points (APs) for instructions on setting up the hardware. To configure the mobile computer, a set of wireless applications provide the tools to configure and test the wireless radio in the mobile computer. The Wireless Application menu on the task tray provides the following wireless applications: • Wireless Status • Wireless Diagnostics • Find WLANs • Manage Profiles • Options • Enable/Disable Radio • Log On/Off Tap the Signal Strength icon to display the Wireless Applications menu
pg 1-13,
Download manual
The Motorola MC9090 can have different keypads attached. If you do change the keypad for any reason for example go from a 53 key to 43 key layout the terminals must be cold booted.
To cold boot an MC9090 running Windows Mobile 5. Partially remove the battery, hold down the On/Off button, the trigger and reinsert the battery. When the orange light on the keyboard flashes release the on/off button and the trigger.
If the on/off button or trigger is held down longer than required this occasionally causes the terminal to get caught in a warm boot cycle
If the device is still not giving the correct key output it may have a faulty keypad.
If you need any more help then please do not hesitate to contact us:-
[email protected] or TEL +44(0)1202 620955
http://www.biastechnology.com/
