Check your touchpad program settings. There should be a tickbox to enable/disable it. There might even be a setting you can change so that accidental taps won't have you clicking on any unwanted links.
Hope that helps.
Testimonial: "The touchpad settings enable/disable tickbox is not highlighted so i can't disable it. Anyone else have this problem?"
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
