SOURCE: Not Booting Up
did u try choosing safe mode.....
if still the problem pesists then it might be that ur OS's has got corrupt
so u can either go for OS recovery
or complete format
SOURCE: Acer computer screen went white and black
If the mouse is newly installed may be theres a problem in the port drive of your acer computer or one of its components been corrupted. So as your monitor doesn't work since display components and its, drive have been missing. YOu have an acer CD, try to repair or perhaps it needs to reformat your Acer computer.
SOURCE: turn my acer on and the screen is black with white
Found this on the Web. If you find this helpful, pls rate me.
Shut down and again start your computer....press F8 while it is starting it will take it to safe mode
Then, please perform the steps below.To use the System Restore Wizard, make sure you're logged on as an administrator, and then follow these steps:
1.Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3. On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, and then click Next.
This should solve your issue but this will disable your latest downloads.
Good Luck...
SOURCE: Windows won't boot up computer
This is the way in which the BIOS is telling you that there is no OS to load - Windows has been corrupted beyond repair.
You can do only one thing - reinstall it.
Hello, doing a "last known good
configuration" Works most of the time. Here is how to do it:
1. Make sure your computer is powered down.
2. Turn your computer on and immediately
start pressing F8 on your keyboard repeatedly until you see a black screen with white writing that gives you a list of boot
options.
3. Use the down arrow on your keyboard to
select the Last Known Good Configuration (Advanced) option.
4. Press Enter on your keyboard
and cross your fingers.
Good Luck!
