I have a Coolpix S220 that hasn't been used in a couple of years.
Hi dear!
1. If you see like window blind on LCD when you camera switch on at camera mode. Check one more thing, press menu botton. You still see like window blind on LCD. and then you have defective LCD unit. Otherwise, you have shutter blades (not dust cover blades in front of lens) defect inside of lens unit assembly.
If LCD defect will be very inexpensive service and easy, otherwise, you bring to local repair shop. (very easy problem)
If Actual picture come out like window blind image,
then I want you load to computer and open the file.
You still see like window blind image. then 200% is the shutter blades not working properly inside of lens unit. Bring to local repair shop unless you are not able. Then I can give a little monkey job! using a tooth brush!
Hope You Luck! A Professional Camera Clinic Guy!
