You can test it by turning you meter to ohms and connecting to both sides of the button on the board and pressing the button.
You can;t check the board out of the machine. Inside the control panel area should be what GE calls a mini manual and wiring diagram. Should be test procedures in that paper work. It should tell you where to test for voltage if the board is completely dead. If you had power, the board can be put into a test mode to check all the different parts and cycles. Hopefully that sheet of paper is still inside the control panel.
