Apple iPad (16 GB) WiFi Tablet PC Logo
j
june ford Posted on Apr 12, 2015
I dot know how to reset my ipad - Apple iPad (16 GB) WiFi Tablet PC
mitchell wyse
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 13, 2015
mitchell wyse
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
555
Points
5
A factory Reset will wipe all the data stored on your iPad...everything will be restored to factory default, which basically means it will be just as you got it out of the box. It can be done by following these steps:
1.)Start by selecting 'settings'
2.)Than select 'general'
when in general scroll down to bottom of the page to 'Reset' and select it.
3.)Than you have the option to do a two things as far as Resetting your iPad.
a.) 'Reset All Settings' - This will preserve all your data but will restore all factory defaults..
b.) 'Erase All Content and Settings'. This will wipe all data and restore to factory defaults.
If you're giving the iPad to someone else or selling it...choose b.
2answers
How do I reset my ipad
1. Plug iPad into the computer with the USB cable. The iTunes on your computer will automatically launch. If not, double-click the icon to start it.
2. Click the name of your iPad at the upper right corner of iTunes, and then the information of your iPad will be shown. Click the "Restore iPad" button in the window to start.
3. iTunes will ask whether you want to back up iPad before restoring. You'd better choose "Yes" for the reset will erase the contents in your device. Then iTunes will start restoring your iPad to factory settings.
4. Click Restore again to confirm. Then iTunes erases your iPad and installs the latest iOS software. After you restore your iPad to factory settings, it will restart. Now you can set it up as new.
http://www.leawo.org/tutorial/how-to-restore-iphone-6-plus-to-factory-settings.html
2answers
I don't know my password to Ipad need to hard reset
iTunes enables you to restore iPad to factory settings. Before you start restoring iPad to factory settings, please note that you need to install the latest version of iTunes on your computer. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPad with iTunes as follows.
3. iTunes will ask whether you want to back up iPad before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPad. Then iTunes will start restoring your iPad to factory settings.
4. Click Restore again to confirm. Then iTunes erases your iPad and installs the latest iOS software. After you restore tablet to factory settings, it will restart. Now you can set it up as new.
How to Restore iPhone 6 Plus to Factory Settings
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
New Christmas gift. Have plugged it in and downloaded Alexa dot app in iPad. Now what?
Open app and follow instructions. Pretty simple setup. Oh and plug in echo/Alexa too.
1helpful
Setting up gave wrong email will not let me fix it
Barry, You may have to do a factory reset and start over, or contact manufacturer for suggestion.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apple iPad mini Retina How to master reset
Perform factory reset Apple iPad mini 2 128 GB
How to Easily Master Format APPLE IPAD MINI 2 RETINA DISPLAY with Safety...
Can't reset the iPad without the pass code
this is apple's lock, i will not want someone to open up my iPad if it is stolen, if not contact apple directly they will assist you after some checks, remember that the code can be reset if you know the apple id and password for that iPad.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
