Question about Whirlpool Washing Machines
What does F09 mean mean for a whirlpool AW0 3561 front loader?
    Top Expert:
  • Whirlpool Master
  • 14,162 Answers
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Posted on Apr 13, 2015
6ya staff
SOURCE:
Marty marty
  • 883 Answers
SOURCE: whirlpool front loader
please clarify the "some times throughs the switch" part...does the timing switch continue to run even though the machine stopped?
Posted on May 25, 2007
Anonymous
  • 625 Answers
SOURCE: What does a F09 error mean?
Since Sears doesn't manufacture its own equipment I need a product code number to access the specific features of your appliance. Email me with that info and I can find what the error codes are.
Posted on Sep 10, 2007
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Whirlpool Duet Front loader
"F02" is a Long Drain error and "F09" is an Overflow Condition. The following two links explain both errors:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
http://www.fixya.com/support/r805532-f09_error_whirlpool_duet_kenmore_elite
The common factor with both links is the drain pump. There's a good possibility that you have something lodged in the pump. The next link explains how to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Follow the links and check the items common to both, as this could be the source of the two error codes occurring. It does not take much to damage the drain pumps in these washers. If you do find something in the pump, clean it thoroughly, and it still does not work, you will have to replace it. Let me know if it comes to this point and I can give you advice on how to order a replacement and how to replace it. I hope this helps you.
Posted on Aug 28, 2008
Anonymous
SOURCE: error message
F DL ERROR MESSAGE
Posted on Dec 11, 2008
Anonymous
SOURCE: Whirlpool Front Loader Washer Model# WFW9600
I had a suds error and then a F 35 error. Turns out I had a collection of junk and debris between the door seal and the drain at bottom of door. Cleared out the debris now my washer is running like a top. (washer senses pressure error, thats why I got said error codes)
Posted on Oct 19, 2009
Whirlpool Duet Front load is displaying E10 and F09 errors
Search internet for:
Make + Model + the word "E10" and "F09"
Consult the owner's manual in the Troubleshooting section.
Mar 06, 2016 | Whirlpool Washing Machines
Error message : e01 f09
First try holding down the cancel button for 10 seconds and releasing (might have to do this 2~3 times). The technician manual is located under the lower front panel. I've heard that locating the CCU (brain box, in lower right) freeing it up and giving it a couple of wacks has worked. F09 is pressure switch, E01 is Thermistor. The tech manual will be a great help!!
Feb 16, 2014 | Whirlpool Duet 4.3 cu. ft. Front Load...
Whirlpool front load washing machine F 09
In general for Whirlpool washers 'F09' means 'overflow'. I would guess that there is a problem either with the water level sensing, with the control board which controls the operation of the water valves or one of the valves itself. Sorry but repair call required ;-0(
If this has at least clarified the situation please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 16, 2011 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My front loader washing machine shows F 9 on the digital screen which relates to water leakage. I have had this problem recitified previously, wherein water somehow leaked into the bottom of the machine,...
Sorry but Whirlpool 'F09' does state 'overflow'. It could be that the overflow sensor is being a bit keen i.e. malfunctioning, and needs a service call ;-0(
Sorry again,
John C
Apr 08, 2011 | Whirlpool Washing Machines
F09
Thanks for using FixYa. Error F09 means heat fault. Please check that the filter is not blocked. The filter should be emptied after every load and/or cleaned once in a week thoroughly. If still the issue is not resolved then you’ll need to get the heat sensor replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 20, 2010 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool 6.5kg front loader 2004 model. On any cycle machine won't pump water into tub and brings up an error message of F09.Electrical control board has black scorch marks on it.Would it just be cct...
You can check 1. power supply first then you can check 2.the door lock is working fine then you can check 3.the motor 4. the drain out valve 5. inlet valve is working fine with direct power supply
If every thing is fine means check the main board of the unit then you can replace that cct board
Jan 19, 2010 | Whirlpool Washing Machines
What does code f09 mean on whirpool 10561
If this is a Whirlpool front loader, "F09" is an Overflow condition error. The following link explains how to diagnose and troubleshoot:
http://www.fixya.com/support/r3608557-f09_error_code
Read through the link provided and let me know if you have any questions. Please post back with a MODEL NUMBER (located on a nameplate around the door opening). I hope this help you.
Jan 18, 2010 | Washing Machines
Aug 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F09 error code for whirlpool Model GHW9250MT
Please click on the following link for an explanation of the "F09" error code:
Read through the information thoroughly and let me know if you have any questions, or require further assistance. I hope this helps you.
Jul 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F09 error code
yes they are take off front panel (lower) and run machine then unplug unit for about 2 minutes this will reset the computer if not inside the lower front panel SHOULD BE a tech sheet this will tell you how to put it in diag. mode and will tell you whats going on with codes and this tech sheet will give you the meanings
Dec 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
Why does my Whirlpool Duet model # WFW97HEXL not detect the blue load and go detergent dispenser cartridge? Front load Whirlpool duet steam washing machine w/ precision detergent dispenser cartridge, (model # WFW97HEXL), does not detect the blue detergent cartridge when placed in the soap dispenser drawer, as a result the pre treat cycle cannot be utilized since it works in conjunction with the blue precision detergent cartridge. Without the cartridge in the dispenser drawer, soap flows freely into the drum, as do bleach, and fabric softener without issue. When starting a wash cycle with the blue detergent cartridge in the dispenser drawer a prompt on the LCD screen asks if the detergent cartridge is being used, you can answer yes to override the question by continuing to press the start button the wash cycle starts but, the pre treat cycle cannot be chosen because the blue detergent cartridge Is not detected and the machine will not allow the pre treat cycle to be overridden because it cannot detect the blue detergent cartridge. With the top of the washer off and by over riding the detergent cartridge when prompted I noticed that the dispenser actuator is cycling and landing on actuator port II but, I believe with the detergent cartridge inserted the actuator should be dispensing from actuator port I. Has anyone seen this issue or can anyone provide any insight into what may need to be replaced. This started occurring after the main control board went bad and was replaced the humidity sensor on top of the dispenser drawer was also replaced as I noticed that sensor seemed to coincide with the float inside of the blue detergent cartridge. Other than the blue detergent dispenser not being detected and not being able to utilize the pre treat feature as a result of the blue detergent dispenser not being detected the machine and all other features are functioning normally.
Dec 12, 2019 | Whirlpool Washing Machines
Washing Machines Logo
249 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
