Bottom thread is still too loose after adjusting thread tensioner
You bobbin tension CAN be adjusted. First, thread your machine with different colors in the top and bobbin, set your top tension at its default, and run a line of straight, and then a line of zigzag stitches, and compare the results at the top and bottom. You will be adjusting your bobbin to your top tension. If the top tension looks like a straight line instead of stitching and the zigzag looks like "chicken tracks" instead of a zigzag, but the bottom looks like a zigzag, your bobbin tension is too loose.
Remove the bobbin case, and locate the straight-slot screw. There are generally two; one is a Phillips and one is straight--you want the straight one. Leave the other alone.
The rule is "lefty-loosy, righty-tighty." If your stitching displays the above symptoms, it needs to be tightened, so turn 1/4 turn to the right--no more--then test again. You will need patience, but don't turn more than that. It is easy to do, but if you don't do it systematically, you can make things worse, and very slight adjustments can alter the stitching significantly.
SOURCE: sudden knotting under fabric
I have an Elna 2005 machine and had a similar but opposite problem whereby the tension up top was too tight - thread wouldn't pull smoothly. I found adjusting the feed dog lever slightly helped the stitches a lot, even though the needle tension up top is no better. Hope that helps! :-s
SOURCE: Yet another stitch tension problem...
Thank you, thank you! I just tightened the screw on my bobbin case and that instantly fixed my thread tension problem. How on earth are you supposed to know about the little screw?! I thank you so much for the tip!
SOURCE: euro-pro 464xc bottom tension loose
Welcome to FixYa!
Loose bottom stitches come from the top, not the bottom. Seems weird, but that's the way sewing machines work.
The dial tension should be set at the mid range and make absolutely sure that you have the machine threaded correctly. Both things will cause a sloppy bottom stitch.
Thanks!
If you find my solution helpful, I'd appreciate a FixYa rating....
SOURCE: thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
-R
SOURCE: bottom tension to tight
There's hardly any way to significantly adjust the bottom, or bobbin tension. There's just a small, flat spring attached to the side of the bobbin case, under which the thread runs. There's adjustment there. You need to adjust the top thread tension via the small thumbscrew that's against the plates on the top thread tension discs. Increase or decrease tension there until top and bottom threads are equally centered between layers of material.
You can adjust presser foot tension with the knurled nut at the top of the machine. I never had the kind of problem you mention though. I set my machine at about 6 stitches per inch or a little more (max is 5, recommended), and presser foot tension is only heavy enough to pull a single layer of material through.
Hope this helps.
